928 Forum 1978-1995
Sponsored by: 928 Specialists
Click in Clutch Pedal ??
Old 09-02-2017, 07:41 PM
Rick3452
Rick3452's Avatar
Default Click in Clutch Pedal ??
Hi guys,
Started today... I'm getting, and feeling a "click"every time a let up on the clutch pedal. It near the top of letting it out.
82 5 Speed
Any ideas?
Thanks!
Rick
Old 09-02-2017, 08:28 PM
GJB928
GJB928's Avatar
Mine started out with a click and intermittently progressed to a pop when my clutch pedal would get stuck trying to push it down. I'm just finishing the job today. I believe the problem was a worn guide tube.
Old 09-02-2017, 11:47 PM
jheis
jheis's Avatar
Years ago, the clutch pedal in my '82 started to feel kind of "wonky." I was in the middle of pre-running the tour I was leading for the inaugural PCA Escape when the clutch pedal broke off leaving me stranded in the middle of nowhere.
My '82 had a clutch pedal that was made out of sheet aluminum that was rolled and seam welded. Later pedals are solid cast alloy.
If you have the early (hollow) pedal, replace it before it breaks off....
James
Old 09-04-2017, 10:35 AM
Rick3452
Rick3452's Avatar
James
Thanks for the info... Anyway to tell if I have the aluminum type??
Old 09-08-2017, 06:19 PM
jheis
jheis's Avatar
Both versions are aluminum (or alloy). The one that broke off was kinda like a seam welded hollow aluminum tube - to save weight, I suppose....
The solid cast version looks more like the brake pedal (but a bit narrower). More like a beam than a tube - if that makes any sense.
James
Quick Reply: Click in Clutch Pedal ??
