928 Forum 1978-1995
Sponsored by: 928 Specialists
Is my '85 auto up-shifting correctly? ***video***
Old 10-28-2017, 10:26 PM
OTR18WHEELER
You can call me Otis
OTR18WHEELER's Avatar
Default Is my '85 auto up-shifting correctly? ***video***
Poor audio, window halfway down, left hand on the wheel, right hand holding the phone.
Old 10-29-2017, 05:57 AM
The Forgotten On
The Forgotten On's Avatar
Upshift points seem normal, even with the rear tires spinning like crazy in yours
They normally shift ~5600-5400 rpm under full throttle.
Maybe time to upgrade the tires.
Old 10-29-2017, 01:31 PM
kombatrok
kombatrok's Avatar
Seems ok, mine shifts slightly closer to redline maybe...
Are you getting wheelspin at 30+ mph?
Old 10-30-2017, 01:29 AM
DeWolf
DeWolf's Avatar
clearly not stock
Old 10-30-2017, 01:40 AM
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
Received 2,464 Likes on 1,461 Posts
Originally Posted by DeWolf
clearly not stock
If not stock, shifts way too early.
If stock, either despirately needs new rear tires or to not be launched in water.
Old 10-30-2017, 02:04 PM
OTR18WHEELER
Thanks for the replys, here are the facts...
car is totally stock, (except for tires, and RMB )
Road is dry, asphalt, strait
Tires are sumitomo
255/40 ZR 17 94W (rears)
about 40% tread
limited slip differential
no brake torque used
gear selector in D
rear wheel spin to 50mph
ambient air temp was 45
Old 10-30-2017, 02:11 PM
Weissach
Weissach's Avatar
Take a picture with the car off, to see where the rpm needle sits. The fact that you're odometer works means it's been opened up, needles sometimes get nudged up or down
Old 10-30-2017, 02:29 PM
OTR18WHEELER
yes, I did replace the gear a few years ago.
It could be off a hair, but the speedometer is correct when compared to roadside speed radars, and my GPS.
Key off^
Key on^
Running at idle^
Old 10-30-2017, 04:45 PM
kombatrok
kombatrok's Avatar
Wheel spin to 50mph?
I don't doubt you, but I've never heard of anyone with a 32v that wasn't supercharged being able to do anything like that... Mine sure won't with a limited slip and moderately sticky Firestone Firehawks and I have Porkens chip, no cats and a tweaked vacuum/emissions system.
Mine shifts all the way at redline when I have the pedal down. I did have to play around with the bowden cable to get it shifting where I wanted it though.
Quick Reply: Is my '85 auto up-shifting correctly? ***video***
