928 Forum 1978-1995
Sponsored by: 928 Specialists
Pulled engine: timingbelt play, i think i made the right decision
Old 01-06-2018, 02:12 PM
wopfe
wopfe's Avatar
Default Pulled engine: timingbelt play, i think i made the right decision
Today i had great progress in dismantling the engine. Found that the belt had a lot of play. So much that i am wondering if the waterpump was even moving(!). I am replacing it for a pk tensioner soon.
I was wondering if people have the same experience when replacing the timing belt. The engine never overheated btw. ('79 euro manual).
Old 01-06-2018, 02:25 PM
FredR
FredR's Avatar
If the pump was not working you would overheat immediately. A slack belt does not stop the water pump from working but in the extreme it does mean there is a good chance of the timing belt jumping teeth- not good if you have an interference motor thus it helps if you advise what year model you have.
Your video suggests the belt is very slack but if you are going to play around with the engine and take on jobs like the water pump/timing belt then you need access to a belt tension tool and then you quantify where you stand.
As a matter of interest why did you pull the motor? Not needed for a timing belt/water pump job- presumably you had some other concern/reason?
Old 01-06-2018, 02:29 PM
StratfordShark
StratfordShark's Avatar
When was it last driven? Would expect TB warning light to be triggered when that loose. I know tension varies with crank position and is meant to be measured at No 1 TDC, but surely that would trigger warning? Was warning system working?
Old 01-06-2018, 02:36 PM
wopfe
wopfe's Avatar
Hi Fred,
Its a '79 euro. I think the pk-tensior will take care of the right tensioning if i am correct when i start putting it back together. I have had the car for 8 years now and never did stuff on the engine and got the opportunity to work in a shop in the winter. There was some oil leaking at the header on the right so i am also going to pull the heads. I am now already happy that i pulled it, it works so much nicer when you have the beast on a stand. Basically take care of everything i will find, including new engine mounts, gaskets and clutch.
Old 01-06-2018, 02:37 PM
wopfe
wopfe's Avatar
@StratfordShark, its an oldtimer ('79), it does not have a warning light it think.
Old 01-06-2018, 03:09 PM
James Bailey
James Bailey's Avatar
So how old is the timing belt ?? And when was the tension last checked / adjusted ?
Old 01-06-2018, 03:23 PM
wopfe
wopfe's Avatar
Not sure, in the 8 years i have the car, i never checked it. So older then 8 years.
Old 01-06-2018, 03:31 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,284 Likes on 1,266 Posts
Note based on your current state,
you would be well served to read the WSM a few times regarding engine disassembly, head servicing and belt servicing.
This Before you touch any of the hard parts.
Old 01-06-2018, 03:36 PM
FredR
FredR's Avatar
Originally Posted by wopfe
Hi Fred,
Sounds as though you are in for a bit of fun. Get yourself one of the Kempf timing belt tension tools- they are not very expensive but invaluable. You will also need to be able to do the valve timing- that is more straight forward on your model compared to the later 32 valve variants.
Hopefully you have a good heater in the garage!
Old 01-07-2018, 09:52 AM
j.kenzie@sbcglobal.net
j.kenzie@sbcglobal.net's Avatar
You don't need and really can't use a tension tool properly with the PKnsr. It's a nice job once you get thing cleaned up a bit.
Good luck,
Dave
Old 01-07-2018, 10:59 AM
SeanR
SeanR's Avatar
Good luck,
Dave
Yea, about that.
Old 01-07-2018, 11:05 AM
FredR
FredR's Avatar
Good luck,
Dave
Dave,
This is a perfectly correct statement however the OP was asking about his stock belt tension and a tension tool is required to determine that- academic once the PKT is fitted but that was not the question..
Old 01-07-2018, 12:23 PM
Ahh. I understand.
Thanks, Fred.
Dave
Old 01-07-2018, 01:55 PM
GlenL
GlenL's Avatar
Amazing...
I wonder when that "auto-adjusting" tensioner does after a decade of belt neglect.
Old 01-07-2018, 03:02 PM
dr bob
Chronic Tool Dropper
dr bob's Avatar
With no attention in at least 8 years, be ready for a few surprises as you get things apart. Old coolant scavenges exposed aluminum, for instance, so there may be some repairs needed for the cylinder heads.
Greg Brown in the US (GregGBRD here on Rennlist) has improved cam tower gaskets that you'll find essential to solving the oil leaks at the heads. Odds of success are significantly better than using the factory gaskets or those in the aftermarket gasket kits.
Use the Gates or factory Porsche belt on reassembly, not the Conti belt which tends to be too stretchy.
Get current guidance from the group here about water pumps. The Laso has been a favorite, but availability has become an issue in the last year or two. Geba and some of the knock-off pumps from Asia have had manufacturing and durability issues. Since this is the last piece you take out/first piece you put in during a front-end disassembly for belt service, you'll want a pump that works for a longer while if possible.
Quick Reply: Pulled engine: timingbelt play, i think i made the right decision
