Geba humor
Geba humor
That’s some quality stuff there.
Chronic Tool Dropper
Issue is at the rear of the impeller where the mechanical seal depends on a "true" face for sealing. Looks like the guy who drilled the hole for the shaft gave his seeing-eye dog the afternoon off.
Reality: If that inner surface is square with the shaft, and the impeller doesn't hit the block, technically this pump is "fine". The thrust variations will be minor but will potentially shorten the life of the bearings. The normal uneven load on the bearings from the belt will take them out long before the varying thrust load will have any effect.
It would be a great project to casually design and 3D print "perfect" water pump impellers. No way to make glass-reinforced nylon pieces by that method, but maybe there are strong-enough materials available. Something softer than the aluminum scroll, smoother than the cast-iron, with a way to pin it to or otherwise index it the shaft. And not shed vanes while running.
Consider also that the impeller can fit over a keyed or indexed (with flats...) shaft, held on to the shaft with a nut or a bolt. That makes it possible to change the seal and the bearings, keeps the bearings in position against shoulders or snap-rings in the housing, with no chance of shaft or bearing migration. Industrial process pumps are designed like this, by the way.
I would have thrown these but I kept them in case I decide to get a motor protector one from ed and these would be the cores.
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
Roger managed to talk Laso into making pumps still for the 928. If they decide to quit again, and we are left with these garbage builds, an E-ROD LS3 is looking WAY more tempting as a long term motor rather than maintaining the original.
Basic Site Sponsor
Basic Site Sponsor
Vegas, Baby!
Buy a new Porsche pump, or Ed's Guardian. Forget about all the other cheap crap out there.
For the record, I have a Guardian pump installed in my car. I like Ed's pump better, that's why I bought it. If it wasn't available, I would have bit the bullet and bought a new Porsche pump.
You,ve got to remove the interior in the Pantera to change out a water pump. It's a PITA, to change, but nothing like doing a WP/TB job, in a 928. I don't like having to do something twice, cause I didn't spend the money, and bought cheap parts.
