928 Forum 1978-1995
Sponsored by: 928 Specialists
Hall sensor multimeter measurements
Old 02-16-2018, 07:54 AM
Marti
Marti's Avatar
Default Hall sensor multimeter measurements
Hi Guys
I was trying to figure out whether an old hall sensor I am replacing is faulty or not using only a multimeter.
The sensor is being replaced anyway with a new one and is off the car, I don’t know how old it is but looks to be in good condition.
When I compare multimeter readings between the pins of the old and new sensor there is a difference between them which was leading me to question whether the old one was faulty.
Does anyone have definitive feedback on whether you can tell with just a multimeter if a sensor is faulty?
Old 02-17-2018, 07:41 PM
Marti
Marti's Avatar
The readings I am getting are as follows
New sensor - no continuity between any of the 3 pins
Old sensor - limited continuity between the two outside pins, reading is about 1890ohms, no continuity between the outside pins and the middle pin.
Most information I could find discussed only what the engine might feel like due to the loss of power from a faulty hall sensor or whether the hall sensor had been detected as faulty by the hammer. It would be good to tell if a hall sensor was faulty with just a multimeter - assuming they have a consistent pattern that can be measured when they go faulty.
Old 02-17-2018, 09:03 PM
StratfordShark
StratfordShark's Avatar
My understanding is you need to check voltage readings from each pin - not resistance between then - to verify sensor operation while it’s attached to loom. One pin is ground, one is positive supply (12V or 5V with ignition on), and the third provides square wave signal but only when engine turning (but you can see an average voltage if you don’t have scope to view waveform). Not sure you can tell anything from the resistance readings you’re taking.
Old 02-18-2018, 12:36 AM
ammonman
ammonman's Avatar
One wire is DC voltage supply (can't remember if it is +5 or +12VDC), the other is the +5VDC pulse signal returning to the EZK and final wire is the braided shield wire to prevent electromagnetic interference. The sensor get s DC voltage from the EZK. This voltage only makes it to the pickup side of the sensor when the gap in the rotor disk behind the passenger cam gear is in the gap between the voltage source and pick-up sides of the sensor. The 3rd wire (shield aka "drain") is there to direct any stray voltage generated by electromagnetic interference to a suitable ground so that is doean't interfere with the signal voltage. If you have a VERY fast digital multi meter or an analog multi meter you might be able to see the +5VDC signal coming from the pickup side of the sensor. Best is to use an oscilloscope to view the signal pulse to verify function.
Mike
Old 02-18-2018, 07:29 AM
John Speake
John Speake's Avatar
The supply voltage from the EZK is 5v. It is a semiconductor device so resistance readings are pretty worthless.
Old 02-19-2018, 09:30 AM
Marti
Marti's Avatar
Hi John
Do you have testing capability for these?
Old 04-14-2022, 09:17 AM
Bedfordman
Bedfordman's Avatar
the Hall Sensor failure mode is to retard the ignition (6 degree I think)
rather than unplug, drive the car and try to feel any difference, as a testing strategy for an installed Hall Sensor: could a good old Timing Light / Strobe show this up on the timing marks?
Peter
Old 04-14-2022, 10:22 AM
FredR
FredR's Avatar
Peter
Peter,
No idea what prompted you to resurrent this thread but disconnecting the sensor should result in a "feel" that something is "different" if the system is working correctly and that depends on the sensitivity of the test driver. If one does not feel any difference then that tells you that either the Hall sensor is dead or a knock sensor has gone south as both have the same effect.
As to the timing light one should be able to see a clear difference however I am not sure if the programmed retard impacts the idle map- I have a feeling it does not for some inexplicable reason. You would probably have to spin the motor at a certain rpm point - say 2k rpms and test at the same engine speed/load factor after disconnection. Helps if one has the timing tables from the cruise map to know what one is looking for. The problem then is at light loads the advance is greater so not convinced this would be a viable approach.
Of course the superior way to know if the Hall sensor is working is to have ST2 and PEMS fitted- that tells one immediately whether they are viable [or not]. .
Old 04-14-2022, 11:31 AM
John Speake
The 6 degrees retard is not applied at idle or moderate revs at light engine load. It's purpose is the protect the engine from damage at high load and higher rpm if the sensor is detected as faulty.
The sensor may test OK with a 'scope when the engine is at rest. But if the insulation of the sensor has cracked and fallen away, when the insulation rubs against the block this will create electrical noise and retard is activated.
Old 04-14-2022, 12:16 PM
Zirconocene
Zirconocene's Avatar
Well, so long as we're already into walking dead threads, here's a fun article I found on testing which might be applicable to someone in the future: https://www.thesamba.com/vw/forum/vi...c.php?t=701391
It will likely only test basic functionality but may be useful to someone.
Cheers
Old 04-15-2022, 07:24 AM
Bedfordman
Bedfordman's Avatar
Thanks, John & Fred. I got such good results from Knock Sensors and CP Sensor replacement. Was wondering if Hall unit would be worth change. Insulation / connector on my Hall Sensor OK, so, will leave as is, for now.
Old 04-15-2022, 02:00 PM
systemsc
Basic Sponsor
systemsc's Avatar
A Hall Sensor, as used by Porsche during the late '80s & early '90s engines with distributor spark systems, provided TDC info for cylinder number one. This when combined with the knock control function allowed for timing control (retard)
for selective cylinders that developed knock data. Those cylinders were retarded up to a maximum of nine degrees in three degree increments. Once the knock system no longer detected a knock, the original timing would be restored.
If the Hall Sensor failed, lacked a signal, or the knock control system failed, all cylinders are retarded by six degrees above 3500 RPM. The reference is WSM 493.421 page 2-18.
Loren
Systems Consulting - Automotive Electronics
Specializing in Porsche cars
http://www.systemsc.com/
Quick Reply: Hall sensor multimeter measurements
