928 Forum 1978-1995
Sponsored by: 928 Specialists
Old style fuse replacement.
Old 08-30-2020, 12:00 AM
Billu
Billu's Avatar
Wire brush to clean all the fuse holders, top and bottom, clean fuse ends, then this
Amazon Amazon
Old 08-31-2020, 03:49 AM
GerritD
GerritD's Avatar
Talking
Originally Posted by R.Pires
Hi,
This is really a newbie and stupid question but, as I've read here many times the only stupid questions are the ones that are not asked, here it goes!
What is the best and more secure way to replace an old style (ceramic, bullet) fuse in my 83S?
First step in security disconnect the battery, that one I know...
Besides having some physical difficulty to reach the fuse board in perfect condition, I know that one of the tabs "moves" to better accommodate the fuse. Is it the upper or lower tab?
Is there some recommended specific tool to do the job?
Thanks in advance for your answer and also suggestions!
Regards
I am currently replacing the old style bullet fuses by new type spade ones.
You can order the spaded fuse holders @ digi-key. It will cost you about $50 for the fuse holders (+spades) and $20 for the fuses.
You only need to solder them together.
Old 08-31-2020, 06:57 AM
danglerb
danglerb's Avatar
I hunted around and bought a batch of old stock sealed glass fuses and swapped all mine out.
Quick Reply: Old style fuse replacement.
