Uh oh: Stuck in first
Pic of old vs new. Took some aligning and pressure to get it in the cup.
Many thanks! Got her back on the road.
I persevered (rediculously) for 6 hrs trying with a large ratchet strap to pull the cup and new bushing onto the ball. Had to shave the new bushing inner lip a tad, which then took 6 minutes to get on. Then backed it up with a 6"clamp/strap as others have mentioned.
Huge thanks to all.
Go Raps
^^^^^^ I don't know if there is a right way or a wrong way, but this is the method I use. I also use a small ratchet strap to lock it all the way down onto the ball.
Then I put the large tie wrap on it to keep the ball from jumping out of the cup down the road.
Good Luck
Good Luck
Huge thanks to all.
Go Raps
