928 Forum 1978-1995
Sponsored by: 928 Specialists
'81 auto - value
Old 10-19-2018, 09:25 AM
the flyin' scotsman
the flyin' scotsman's Avatar
Default '81 auto - value
A local is selling his family car that hasnt ran for + 10 years. The owner had issues with the car (perhaps timing belt) and took some the front end apart. The project was delayed for a variety of reasons and then the owner past away.
Bottom line; its a '81 MY auto not running that essentially, if the engine tuns over, will need at least a timing belt project (belt, gears, w/p) or even a full engine build. 928 Int big sale coming so perhaps can source engine there.
Old 10-19-2018, 09:54 AM
Garth S
Garth S's Avatar
Hi Malcolm,
Non-interference - aerosol fogging oil in the plug wells and (gently) turn the crank. If it turns, even with the TB off, likely good to go and proceed to a TB/WP, far easier than an S4 - compression/leak down can be checked later, but generally not an issue.
Do look at the left cam nose, as some do break and a possible reason for the PO's tear down.
Old 10-19-2018, 10:12 AM
Jadz928
Jadz928's Avatar
Non-running 81 auto still doesn't command much. Depending on condition of body and interior, $500-$1000
If it's a 78-79 5 speed, double to triple that. If it's for Docmirror, $250.
Old 10-19-2018, 10:17 AM
the flyin' scotsman
$250 for Doc!!! now thats a huge stretch
Old 10-19-2018, 10:21 AM
the flyin' scotsman
Originally Posted by Garth S
Hi Malcolm,
thanks Garth, I was thinking exact same, its sky blue on a linen interior with no rub strips. Going to have a good look this aft as to what else it may need.
As been said many times before its perhaps needing $15k in parts/repairs to be a $10k car for sale.........cheers
Quick Reply: '81 auto - value
