928 Forum 1978-1995
Sponsored by: 928 Specialists
Melted Fuse Holder/CE panel
Old 12-26-2018, 04:26 PM
Fabio421
Man of many SIGs
Fabio421's Avatar
Default Melted Fuse Holder/CE panel
1988 S4 - Yesterday I found that my fuel pump fuse was melted (but still working). I got the fuse out in pieces but the black plastic fuse holder is melted beyond use. Is this black plastic piece available as a part? If so, what is it called? I trued searching "fuse block" or even just "fuse" on 928 International and this part didn't come up from what I can see. Although many of the items do not have a photo. Any help is greatly appreciated. Thanks
Old 12-26-2018, 04:33 PM
Kevin in Atlanta
Kevin in Atlanta's Avatar
928Intl will be able to help you.
Old 12-27-2018, 04:24 PM
linderpat
linderpat's Avatar
Received 2,258 Likes on 1,258 Posts
A bigger issue is why did it overheat. The fuel pump may be failing, so that should be addressed too.
Old 12-27-2018, 07:29 PM
Kevin in Atlanta
Corroded fuses are a common cause. A proper fuse in good shape should pop.
Old 12-27-2018, 07:51 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,278 Likes on 1,263 Posts
if the connection at the fuse was corroded then the amount of heat on a hi draw line will easily melt the surrounding plastic.
Based on the info provided your fuse connection was dirty or not clamped enough to provide max energy transfer.
Use deoxit 100 and you may have to replace the fuse holder pins in the CE panel as well as the plastic parts that have melted.
NOTE the section that you are working is specific to your year,
so just using any old combination of parts would not be a smart thing to do.
carefully evaluate the pins on the back of the CE panel for the correct installation
Old 12-27-2018, 09:42 PM
ammonman
ammonman's Avatar
there is an S4 CE panel available on Fleabay right now (no affiliation but from a good seller) for a reasonable price. I picked one up a few years back as a donor for some repairs on my panel (cooling fan fuses.) Nice bit to have in the spares bin. The entire panel comes apart so you can harvest individual parts for repairs.
Old 12-28-2018, 12:59 PM
Captain_Slow
Captain_Slow's Avatar
What Mike said above and I hope this helps... https://rennlist.com/forums/928-foru...nor-block.html
Old 12-28-2018, 02:32 PM
Alan
Electron Wrangler
Alan's Avatar
That is never the cause of this kind of damage - there is a poor electrical connection at the fuse terminals
Alan
dzaprev (10-29-2019)
Old 12-28-2018, 05:58 PM
C531XHO
C531XHO's Avatar
I had the same problem on mine. The parts are difficult to clean up without damaging the plastics. I bought a flying fuse holder and connected it to the original wires disconnected from the back of the original fuse holder - works perfectly
Old 01-05-2019, 05:40 PM
Alan
Electron Wrangler
Alan's Avatar
Be aware that if re-using fuse-holders from another panel:
1) Only panels 1985+ are compatible for ATC/ATO fuses
2) Each fuse holder block is numbered (sequential groups of 5) look under the lip - not obvious when installed
3) Fuse holders are not all configured the same - the input side (top when installed) has shorting buss bars across some inputs (config varies)
4) Even between years specific fuse holder numbered sets have different configurations - so only a correctly numbered fuse holder from the same model year (panel type) is a guaranteed match
5) Otherwise you will need to test any candidate fuse holder and ensure it matches the one you need to replace (you can swap internal terminals/terminal sets with other blocks
6) You can see the fuse holder input shorting config for your year on the Wiring diagram Central Electric Page (look at the fuse section)
THIS IS VERY IMPORTANT - YOU CAN SEVERELY DAMAGE YOUR CAR IF YOU USE THE WRONG PARTS
Alan
Old 01-05-2019, 09:05 PM
Captain_Slow
Alan was a big help during my CE refurbishing job. His information regarding compatible panels and blocks were key to a successful result. Of course the most important thing to do is visually compare the architecture of the copper conductors inside the blocks. It's not hard and nothing to be afraid of - but seriously important to be aware of and match exactly.
Old 10-28-2019, 08:16 PM
Tomkat80222
Tomkat80222's Avatar
I'm heading down this road as well. The number 8 fuse had blown and I replaced it and while doing so found all the fuses had a layer of corrosion on them. I cleaned them all up and sprayed each socket with Deoxit 100 and put in a replacement 5 amp fuse that started to pull apart (metal from plastic) as I was installing it. Not a good sign, but this was the only one I had. I turned on the lights and all was good. Drove the other night and within 1 mile I was smelling smoke!! Pulled over and ripped off the cover to see a little smoke and the fuse housing melted. I grabbed at the hot mess and finally got the fuse wire out. I'm a little confused as to why this would happen this way and after spraying the sockets. Bad fuse? Or as Alan has said, is there a poor connection? Or do I have a short and the fuse failed.
Old 10-28-2019, 09:05 PM
Kevin in Atlanta
Poor connection - not good enough to blow the fuse, but enough to melt everything around it.
Old 10-28-2019, 10:21 PM
Jason89s4
Jason89s4's Avatar
If I had a 94 Minerva Blue GTS 52K miles I would spend $35 and replace all the fuses with quality new ones, not just clean them. Oh, and another 40 bucks and replace all of the "53" relays.
Oh wait, I do that with all my cars.
-Jason
Old 10-28-2019, 10:49 PM
The Forgotten On
The Forgotten On's Avatar
I never really realized that the resistance could get so high to melt all of that stuff.
Makes me glad California is so dry for once.
Quick Reply: Melted Fuse Holder/CE panel
