928 Forum 1978-1995
Sponsored by: 928 Specialists
Grinding with new Starter
Old 01-12-2019, 02:57 PM
Sean79 5spd
Sean79 5spd's Avatar
Default Grinding with new Starter
Recently replaced the starter with a reman unit. Worked fine a few times (2) but now only a grinding noise and no engine turn. Is it possible the flywheel teeth are stripped? I know the starter is in tight.
Old 01-12-2019, 03:40 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,281 Likes on 1,265 Posts
It more likely that the last thing you touched is the probelm.
Disconnect the battery
Remove the bell housing with the starter and inspect the flywheel teeth,
turn the engine via the crankshaft
Old 01-13-2019, 11:59 AM
Petza914
Petza914's Avatar
Received 6,192 Likes on 3,948 Posts
Is it possible the starter isn't properly aligned to the flywheel and the starter pinion gear is either not making it to engage with the flywheel teeth or not able to retract and binding?
Old 01-13-2019, 02:21 PM
Sean79 5spd
I'll check the alignment in case on bolt wasn't all the way in. Hard to image though. Also, the early years didn't have a bracket, the starter bolts directly to the bell housing.
Quick Reply: Grinding with new Starter
