Looking at a 84 and have a bunch of questions
Seems like (in order):
GTS (93 - 95)
OB (78 & 79) Far more the 78 than the 79.
GT (89 - 91)
Maybe the 86.5. Depends on who you ask.
This is all based on low miles, original condition, good to excellent condition. So far, 'restored' cars don't seem to be worth a whole lot more. And we are a loooooooong way away from a pile of rust with a VIN plate and a title being worth anything.
Maybe the Euro S2 (84 - 86) and the Euro S (80 - 83). The problem with those is that the vast majority here in the US were brought in back in the 80s and early 90s via the 'federalization' route. So they were altered, sometimes significantly.
GTS (93 - 95)
GT (89 - 91)
Smooth shift, early, is generally a vac leak. Could be local or at hoses top of engine or both.
That it runs and shifts is a great positive!
I've gotten great enjoyment from the whole regimen of research, diagnose, improve and drive.
The availability and quality of documentation for these is top notch. Parts are still very readily available, though higher in price now than a few years ago. 84 electrical diagrams are funky but we've worked out the nuances. When i review a car I'm looking for absence of harness or wire burn. That is key. Here's how. Inspect big harness running along pass fender for any burn thru. Also crucial, inspect fuse box at passenger feet. Pull back carpet, flip up wood cover. Flashlight, get your head in there and look at all the wires as they exit distribution plugs along bottom row of fusebox... made easier if you also temporarily remove the lower wood panel with a bigger Phillip's head, two screws, easy. also check fuse holders at top of panel for burns, if found count positions from left to right and note which had burn marks.. If absent of any insulation burns or fuse burns you are way, way ahead. A series of things cause burns, mice, headliner lights shorting on body, over fusing....bam proliferation and hell. Examine box so you know. They nearly always burn thru too within a few inches from plugs leaving box if they short anywhere.
Don't vastly overpay going into this if there is pent up maint, but don't worry to much either. If straight body and no mice infestation you are way way ahead in refresh effort . The 16V engine is awesome. I love the 84 cars. The auto has great advantage that it it also suitable for stop go traffic. 5 speed is pita on a commute. Pics would help. Btw, replace fuel lines very early in your process.
Fantastic car, any year, if you are DIY guy it will be fun. There are a few hundred grey market 84s in USA also, noted by a twin distributor on top of drivers side of engine, if it by chance is one of those it's a big bonus. But the stock USA is fun too.
The 928 is 1:1 in top gear. There is no overdrive, and that is both auto and manual. it is made up for with a high (numerically low) final drive ratio in the differential, typically 2.2:1.
So you were talking about restoration costs when you stated, ".just keeping it running is easily $2,000- $3,000 a year."? That's confusing. To me the cost of restoration is the money spent to get a car in a running condition, not yearly maintenance to upkeep it after the restoration. I spent 15K to just get my car running in the first place. Now that it does I spend about 1200/year to "just keep it running". Sure if you want to amoritize all the costs then the yearly cost will be higher. ......
More like the reality that often 928 Owners toward the end of their ownership or after one pain full experience at a repair shop start neglecting the car and not maintaining it. They no longer spend the $2,000 - 3,000 for several years until it gets sold as a " basket case " needing a basket full of money to simply catch up. Sure it makes a great hobby for a do it yourself guy it is just not an inexpensive one. There is something about the Pretty Woman syndrome.... wanting to save a car. Just be sure to start with Julia Roberts and NOT Julia Child.......
8th Gear
Shameful Thread Killer
Everything devolves to "how much"?
If you want to keep it, make sure it hits all your buttons. WANT an auto? Like the color? etc. You may only spend $400 a year. You may spend $20,000 the first year, and nothing for 6-10 years.
I don't know how the DB9 was, but the 928 is one of the finest GT cars ever made. Even today, they're a paragon of high-speed highway comfort; even the early cars.
"he's just $15,000 away from a $10,000 car" --- I can tell inflation has arrived...when I joined the forum it was $10k from a $5k car!!
I recently has an 82 manual for a year and what I liked about those years are:
- Smooth engine performance
- Still plenty of torque for spirited driving
- Less worry about thrust bearing failure
- Less worry about TB failure
- IIRC the 82 ran on 87 gas too!
It actually may have been starting in second due to limp Bowden cable. Its things like this that help us bottom feeders score these cars inexpensively.
I am new to the forum and am looking at a basket case 928 with A/T and 158k miles.
Have not seen the car yet, but have talked to the owner and am thinking of buying the car.
1) It runs but the timing belt has unknown mileage and age and I have seen replacement kits from $200-900, is there a particular kit that is better than the rest?
2) The transmission shifts smoothly but always early, I have read about a governor that that can get gunky and need cleaning or is this assign of a major tranny issue? Could a tranny shop handle this, if I need a rebuild or would I need to find a porsche specialist?
3) It has a few electrical issues, one being the pass. window doesn't work. Is the 928 electrical system fairly easy to track down issues or are multiple systems on the same circuit?
4) Sunroof works slowly, is it more likely to be the motor or is it common to be a track or lube issue?
While I have never owned a 928, I have restored several cars and want to get a feel for if I should pass or whether this might be a viable project for me, so any help is greatly appreciated.
If its the right price take it
