928 Forum 1978-1995
Sponsored by: 928 Specialists
82 five speed cluster not lighting with key on
Old 05-03-2019, 08:17 PM
Rick3452
Rick3452's Avatar
Default 82 five speed cluster not lighting with key on
Hi guys, Usually all the cluster "check" lights come on when key is turned to ON, today only the low fuel, parking brake, and stop light comes on and when I start it they go off. For some time now when only these come on, after I drive for a while, and while driving ALL the lights come on until I shut it off and restart it. Today they never came on, and to complicate things. while on the highway, about 75, I noticed the volt meter was pegged at 16 so I put on the lights and the car SHUT OFF. Cruised over to the breakdown lane, turned key off, restarted as normal and ran fine for rest of day but still no Cluster check with key on. Everything else works, all dash lights, gauges, headlights, etc.
22 years with this car Still Love it!
Old 05-04-2019, 09:29 AM
Majestic Moose
Majestic Moose's Avatar
That is a strange problem. I would say your central warning controller is failing but I don't think that could possibly cause the engine to shut off and the volt meter is independent of that system. Have you done any work around the instrument pod lately?
Old 05-04-2019, 09:33 AM
Petza914
Petza914's Avatar
Received 6,190 Likes on 3,947 Posts
I'm thinking your ignition switch may be on the way out.
Old 05-04-2019, 12:55 PM
Rick3452
Rick3452's Avatar
Done nothing, Just reconnected the battery after three weeks .....
Old 05-06-2019, 10:44 PM
dzaprev
dzaprev's Avatar
The ignition switch will do that. I have several go bad thru all the 928 I have owned.
Old 05-07-2019, 12:00 PM
bwarren97
bwarren97's Avatar
My ignition switch just likes to shut my headlights off sometimes while I'm driving
I figured it out tho, so it doesn't happen anymore
Old 09-03-2020, 09:39 PM
CBR944
CBR944's Avatar
My '82 had a similar issue - although without the car shutoff issue. The central warning unit has a BD437 transistor and a 22uf capacitor that are essential for the 'bulb test' function. If either has failed the bulb test doesn't work. An easy fix if you're handy with a soldering iron. Note MY84 on has a different central warning unit which isn't compatible if you end up looking for a replacement.
David
Quick Reply: 82 five speed cluster not lighting with key on
