928 Forum 1978-1995
Sponsored by: 928 Specialists
1990 S4 Surging - Barely Running
Old 05-06-2019, 06:00 PM
928 at last
928 at last's Avatar
Unhappy 1990 S4 Surging - Barely Running
Hi All,
Spent a few hours yesterday using "search" and didn't come up with anyone that had my specific problem (I may be being too picky here though). So, Saturday morning I take the car out to grab some groceries and etc., and the first stop, no problem everything working just fine. Second stop, car warmed up but not heat soaked, stopped for maybe 10 minutes, and when restarted, surged a couple times and stalled. Car can be kept running a bit longer with feathering the throttle, but, no revs and no power. Flat bedded it home, let it go back to stone cold, started and no change. Disconnected the battery for half an hour, reconnected after checking that things were charged, and no change. There is a strong smell of gas at the rear of the car when it runs. Top end refresh was done about six - seven years back IIRC, with new TPS, CPS and Hall Sensor included. MAF may be original, I don't know. Same with the computers.
Suggestions on the likely culprit or where to start checking?
TIA!
Old 05-06-2019, 07:24 PM
FredR
FredR's Avatar
First suspects to eliminate from your investigation invariably are the LH, the MAF and the CPS If you are getting a strong smell of fuel from the rear that may suggest the fuel pump is running- you can easily check for that by listening from underneath the fuel tank. You should also check to ensure there is no leak at the rear but unlikely i would think. The TPS and Hall sensor are not suspects based on your description.
If you can, swap out the MAF and the LH for known good ones [or try yours in a running 928 S4/GT/GTS].
At the moment my prime suspicion would be the MAF or the wiring inside the connector but...?.
Old 05-06-2019, 09:36 PM
928 at last
Thanks Fred! Yes, I'm quite sure the fuel Pump is doing it's thing. I have a spare MAF to try out on the shelf (Rebuild acquired with some other parts). I'll go there first and report back.
Old 05-06-2019, 09:46 PM
Richard S
Richard S's Avatar
Running on 4 cylinders? Fuel smell could be unburned fuel from the exhaust?
Rich
Old 05-06-2019, 10:01 PM
928 at last
Rich
Doesn't seem to be. There's no lights flashing on the relay and the last time (was a left / right temperature differential) the car ran a lot better on four than it's doing right now.
Old 05-06-2019, 10:12 PM
928 at last
Update:
Just went out and tried it again. No surging now. Fires right up as usual and immediately dies. Giving gas helps, but hardly noticeable.
Old 05-06-2019, 10:24 PM
928 at last
Just had a thought. Although it doesn't explain the fuel smell, I wonder if the fuel pump relay hasn't packed it in......hmmmmmm.
Going to try that next.
If it works, I'm really going to feel like an idiot.
Old 05-06-2019, 10:32 PM
dzaprev
dzaprev's Avatar
What about a fuel pressure regulator?
Old 05-06-2019, 10:37 PM
928 at last
All redone with new Bosch bits a couple years ago. I haven't checked the vac lines for fuel though.
Old 05-06-2019, 11:32 PM
Adamant1971
Adamant1971's Avatar
Failed LH is my guess. When mine died the symptoms were similar. That’s if all your relays and dampers check out.
Old 05-07-2019, 02:25 AM
dr bob
Chronic Tool Dropper
dr bob's Avatar
Start the diagnosis wih relay-relay-relay. Injection, fuel pump, ignition.
Clean the battery positive termainal connections. These include the feeders for the fuel pump and the injection system.
Your symptoms mathch a failing LH controller. Test yours in another car to verify its function. Known-good rebuilders add labels to the case. If yours has no rebuilder label, it's an even bigger suspect.
There's a great document from Wally Plumley titled "Annual Electrical Maintenance Protocol" that' an esssential read (and execute) for 928 owners. Many owners operate in "reactive mode" and only look for problems when the symptoms appear. A huge number of annoyances are avoided proactively by doing stupid-simple things like cleaning ALL the grounds, cleaning battery terminals, looking for hot relays and fuses, cleaning door switches. I hate getting stranded by Stupid Stuff, and firmly believe that the cars can be very reliable drivers with just a few hours of prophylactic efforts each year. Good connections and a good battery and alternator work wonders.
Old 05-07-2019, 12:10 PM
Adamant1971
Rob, you can bring your LH to me and I can test it. Unless you can find someone closer. I’m in Burlington.
Old 05-07-2019, 12:38 PM
Taguid
Taguid's Avatar
I've seen it happen when fuel dampers and/or FPR diaphragms are no longer holding and fuel is being fed into the vacuum line. Too much fuel dumped into system. Check with a Mightyvac to see if they hold vacuum.
Old 05-07-2019, 09:55 PM
928 at last
Thanks! Improbable there's someone closer Adam. Just have to find the time to run out there assuming the other items check. How long does it take?
Old 05-07-2019, 10:44 PM
Adamant1971
15 minutes max to test it.
Quick Reply: 1990 S4 Surging - Barely Running
