928 Forum 1978-1995
Sponsored by: 928 Specialists
Anyone successfully revived a tired rear S spoiler?
Old 07-18-2019, 08:31 AM
drooman
drooman's Avatar
Received 2,011 Likes on 698 Posts
Default Anyone successfully revived a tired rear S spoiler?
Looking to save a UV baked rear S spoiler.. it's straight and un-damaged except for being very dried out. The pores of the upper surfaces have "opened up" a little, making them not as smooth as the non-UV exposed areas.
As the title of the thread states, I'm looking for real world experience on these. There are hundreds, maybe thousands, of products that claim they are great for this...but I'd rather not re-invent the wheel if real results have been obtained already.
I'd prefer not to buy a new one, if you check the prices be sure you are sitting down.
I'd prefer not to paint it either, but that's only because every one I've ever seen painted looks like sh*t
Thanks in advance, I'm sure many of us have worked through this challenge already.
Old 07-18-2019, 08:43 AM
buccicone
buccicone's Avatar
Truck bed liner. The smoother textured stuff.
Old 07-18-2019, 09:30 AM
Range Rover
Range Rover's Avatar
I've had great success using Plasti Dip to revive front spoilers. I imagine it would be a good solution for rear spoilers because it should remain flexible. Before and after:
Old 07-18-2019, 09:35 AM
G8RB8
G8RB8's Avatar
I assume the S4 is the same or similar material. I cleaned mine well with soap and water and slathered on Back to Black layer after layer for weeks every time it starting looking rough until it finally stabilized and wouldn't take up any more. It took almost three bottles. YMMV
Old 07-18-2019, 09:41 AM
drooman
drooman's Avatar
Thanks guys.. however;
The rear S spoiler is a different material than the S4 front, S4 rear, and even the S front spoiler. The fronts are some sort of plastic hard surface material, and the S4 rear is quite hard also. The S rear spoiler is much softer and much more flexible rubber (like) material. I think this is why they do not respond well to paints, I imagine significant adhesion problems and thermal expansion issues with these.
You can't hand squeeze any of the other spoilers like this.
Old 07-18-2019, 10:51 AM
bureau13
bureau13's Avatar
I was using Back To Black on it for a while. It would look pretty good for a few days. When I had it off while the car was painted, I said **** it and painted it with some flat black trim paint. I think it looks OK. I gave it a couple coats, not too thick. It's only been a couple months, so I have no idea how long it will last, but it's been longer than the Back To Black. If it needs it again in a while I can do that...not that I really want to pull it off/put it back on again.
Old 07-18-2019, 12:27 PM
GT6ixer
GT6ixer's Avatar
Andrew, google "heat gun on oxidized plastics". I've never tired this technique but have been meaning to. I have no idea if it will work on the spoiler. Might be worth a try on a small inconspicuous spot.
Old 07-18-2019, 05:02 PM
U-928
U-928's Avatar
I've tried this. Doesn't work. Too much rubber content i think. Works well on my old VW door trim and bumpers though.
Old 07-18-2019, 05:33 PM
Landseer
Landseer's Avatar
I used a tube of silicon dielectric grease.
Basically a longer chain version of what is probably in the thinner back to black referenced above. Dimethicone.
Old 07-18-2019, 06:10 PM
GT6ixer
GT6ixer's Avatar
That's good info. Yeah I was wondering if the rubberness of it would yield the same results. Now we know.
Old 07-18-2019, 06:14 PM
Ladybug83
Ladybug83's Avatar
nextzett 91480615 'Gummi Pflege Stift' Rubber Care Stick - 3.4 fl. oz
Amazon Amazon
Old 07-19-2019, 08:44 AM
Matt Propson
Matt Propson's Avatar
Hey I know this is going to sound silly but black shoe polish works the easiest and looks awesome I ve been doing this for.over 20 yrs on various Porsche's I've owned
Old 07-19-2019, 08:53 AM
ptuomov
ptuomov's Avatar
The rear spoiler material is different from most other materials used in the car. I think Porsche started putting rubber layers on the spoilers because they were afraid of American pedestrians walking into them and suing the car owner and manufacturer (realistic assessment). The rear spoilers have to be elastic and are basically rubber.
This is about the turbo tea tray:
Sorry about the image quality
Old 07-19-2019, 10:58 AM
SteveG
SteveG's Avatar
Rick (Wyattsride) did a revive on his '85 I believe with multiple apps of Back to Black. Whatever he used, you should ask him 'cuz it is pliable, etc. and you know he has a bunch of plastic trophies so there's that. I'm jealous.
Quick Reply: Anyone successfully revived a tired rear S spoiler?
