Ljet crank no start NO spark
Hi guys
I have another thread about my thermotime switch, but I think this is probably a separate issue.
For the past couple of years my car, 84 US automatic, has been getting more difficult to start. I can smell gas after long cranking so I think I have fuel delivery. Jumped the FP relay, FP audible, but no change.
I checked the coil output to the distributor and I have NO spark. Checked with spark tester and timing light lead. Green wire was replaced 4 or 5 years ago. Coil unknown age. I will go through ohming out the coil lead and the coil itself, but any suggestions are appreciated.
Thanks,
Dave
Thanks,
Dave
Hi guys,
I have some data:
No spark at coil wire tested with spark tester and timing light
batt voltage: 13.2V
Coil measurements:
terminal 1 voltage: 1.7V
terminal 15 voltage: 4.5V
coil wire resistance: 1.1 K ohm
coil secondary resistance term 1 to 4: 10 K ohms
primary resistance term 1 to 15: 0.5 ohm
So coil seems OK. Will check green wire connections and distributor.
Thanks very much,
Dave
I have some data:
batt voltage: 13.2V
Coil measurements:
Thanks very much,
Dave
Last edited by j.kenzie@sbcglobal.net; 02-29-2020 at 10:27 PM. Reason: wrong reading on dvm
The factory workshop manuals have an excellent diagnostic test flow for no spark in Volume 1A beginning at page 28-11. The manual can be downloaded at http://www.ligeti.com/928/
Team Owner
You might need a new fuel injection relay,
your car has the compound relay
mkhargrove (04-03-2020)
Inventor
Check/clean the TSZ spark box connectors. Plug in a known good one to test.
hacker-pschorr (03-01-2020)
Thanks, Ken. This problem has been coming on for some time, consistent with building corrosion or gradual failure of ignition box. I'll be looking at it.
Dave
Dave
Team Owner
Plug in your spare relay you do have a spare
Hi Stan. I do have a spare fuel pump relay, but no fuel injection relay. Never knew I'd need one. Can I make a three way jumper? My green wire is pretty new and I understand the ignition modules on these cars rarely fail. I'm looking for single component failure somewhere here. It looks like I have good voltage to the coil and the coil resistances seem OK. Sounds like coils rarely fail also. So I like the idea of relay, relay, relay...
Thanks,
Dave
Thanks,
Dave
BTW one of the drawbacks of a supercharger install is that it makes access to many components much more difficult. I will get there in checking the ignition module and green wire connections, but I have to remove some SC piping to do it. Just takes time. Also I'm working off a ladder, since the car is on a storage lift. I'm getting old too. I'm not complaining, just explaining why I might seem lazy and just want to check easy things first.
Thanks for all the help.
Dave
Dave
Hi Stan,
Looking at the 84 wiring diagrams (different than the 83), it looks like I can jump the L-jet (AFC) relay with a Y-jumper going terminal 30 to two terminal 87's. I may give that a try unless you see a problem.
Thanks,
Dave
Thanks,
Dave
Team Owner
I would suggest to get a new relay and use it ,
many times a jumper has fried an otherwise perfectly working harness.
Given where the car is you should be using the part that will only work in one position
Team Owner
Keep us posted Dave
