Skimming S4 heads advice
#31
For what it’s worth, the old notes I have say that the ‘87 stock head has a chamber volume of 38.7cc and it goes down to 34.5cc with a 0.020”/0.5mm cut.
#32
Basic Site Sponsor
Basic Site Sponsor
There's a high quality machinist, there!
Please tell me that he only did that to one set of intake valves, realized his mistake, and stopped before he ruined any more valves.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
#35
I think the head is shaved off about 0,2 mm. The water bridge is not a big issue, I think you can file the bolt holes. I do not think it will be an issue where it fit into the block.
Regarding the Volvo head (post #12), which was shaved off by one mm, I later advanced the camshaft setting by four degrees (two degrees at the cam) which lead to a noticeable improvement of the mid range torque.
Åke
#36
No clue what it came off of. It passed along my FB feed from Engine Labs as I was reading this thread and thought it amusing.
#39
That is a scrap head I have been using for head porting experiments. If you like to know more about porting have a look here (start at post # 218). https://rennlist.com/forums/928-foru...ughout-15.html
Åke
Åke
#40
Åke
#41
If you do it right you will end up with a good improvement of flow and power. I remember you have a prototype intake manifold. Trust it will outflow the stock manifold which is designed for good engine torque in the lower to mid range rpms. The picture is showing the difference between a racing S4 intake camshaft and a stock ditto. You need something in between.
Åke
Åke
The intake is a single plenum long runner type to try and counter balance the lack of a flappy and the fact that I will not be using high RPM. When I say long runner they are calculated to reach maximum power at about 6k. Even achieving a length that long was pushing the boundaries of space available. It is difficult to say without testing back to back on a flow bench but the intake should provide a big improvement over stock.
#44
I did take the time while the head was off to perform a "budget porting job" retaining the standard valves. Given the increases in flow measured in the porting/polishing thread I thought it worthwhile doing. The finishing on the standard head around the valve seat inserts are quite 'basic' and there is a good amount of meat on the valve seat without destroying the 3 compound curve to play with. I also did a minor amount of valve deshrouding on the exhaust valve for what it's worth. I try to use Dave Vizard principles where possible but the heads as great in design to start with that there is not a huge amount that can be done. I was careful to try and leave the work I did rough enough not to destroy any laminar air flow properties that the rough casting has.
I am currently putting the engine back together after doing the head gaskets and water pump. I will be fitting the new manifold now to see how it goes and hopefully get some mileage under the belt.
#45
