Transmission Mounts $145
Basic Sponsor
I have stock of new aftermarket transmission mounts - excellent quality and a great price of $145 each.
New from Porsche these are now $460 each.
https://928srus.com/products/copy-of...-79-95-porsche
Just saw these in person this morning. Very nice quality~!
Hi Alex - Definitely a DIY project. It's literally 2 bolts holding each of them on. Look under your car; if the transmission is sitting on the cross-member, your mounts are shot. Here are before and after pics of mine:
Sitting on the cross-member. Nicht bueno
A gap between the cross-member and the transmission. Sehr bueno.
How many do you have Roger, and will you be getting more?
What brand are these mounts?
Chronic Tool Dropper
This is a spectacular price on these mounts. I played some trying to add different stuffings to the cavities to bring back the height. I was chasing hot air intrusion into the cabin when I changed mine. The differential height looked OK, and it turned out the old/original mounts were only about half collapsed using the cross-member space as the guide. After a few failed attempts at a serviceable hack, I put the new mounts in. Hot air problem solved, plus way less conducted gearbox noises into the cabin. You'd thing the 'slush' in the auto box would make them quieter. They can be if the gearbox is at proper height.
Now I hear can clearly the fuel pump whining.
Installed a set this morning on a car with a pronounced vibration in the driveline. Much, much better.
Pic of Cylons.
Pic of Cylons.
Team Owner
I just sent Mercedes a text to add two sets to my last order,
thanks Roger and crew
Just a small note on changing the mounts to make sure you check the shims if needed so clearance and load distribution (left/right) I even. Follow the instructions in the WSM reference: 37-123 "Adjusting Transmission Suspension".
