This looks genius..
Administrator - "Tyson"
Too funny, earlier today I saw a video on FB about AMSOil coming in a similar pouch:
https://www.amsoil.com/c/gear-lube/25/
I see this catching on very fast throughout the industry.
Real men use hand pumps.
Chronic Tool Dropper
I bought this filler gizmo at WalMart a few years ago. Here it's on Momma-zon: Screws to the top of the plastic oil bottle. There's a valve built in so you can get things into position before starting oil flow. That clear vinyl hose is, well, clear vinyl hose. Buy a longer piece so you can set a big bottle on the workmate and drag the hose end down to the fill plugs. Hose pincher offers very local shutoff this way. I usually toss the hose with the oil after every session, since most oils seem to darken and crispify the vinyl after not very long.
With a few modifications, this should work for trans fluid etc. Cheap enough- just need to modify the outlet- looks easy enough
https://www.harborfreight.com/05-gal...yer-56167.html
That's cool but unless you use the same fluid in all the cars you work on, you'd need one pouch for each fluid to prevent contamination. I use either a screw on bottle pump or a fluid extractor in reverse.
