Cut out and running rough.
1988 S4 322,000 miles.
This happened awhile back, as I was turning into my drive the engine cut out, I tried to restart it, it would start and then cut out after a second.
I left it for awhile and tried again, it would start and just about idle, if I touch the throttle it just dies, if I’m very careful on the throttle I can get it to 2,000rpm but no more, it just wavers like on a throttle limiter.
I’ve tried it a couple of times since with the same results.
It was running fine before and I’ve not done any work on the car recently.
It had a rebuilt MAF in 2007, rebuilt LH ECU in 2011, new fuel pump in 2018.
2 videos.
Any suggestions or ideas would be welcome.
Ivan.
2 videos.
Ivan.
Team Owner
take your LH and EZK and MAF put them into a good running car do one at a time
Team Owner
Post a service question and your location
Update
Have done the following with no change.New MAF
Computers checked
Fuel pressure checked
Coil resistance checked
Ignition amps swopped
Temp2 sensor checked
14 pin plug cleaned.
Computers checked
