1987 S4 radiator fans not blowing
where is the switch located which controls the radiator cooling fans...mine have stopped functioning. Normally they will kick of even after the ignition is shut off & is there a way to test the switch. or could it be something else causing the no-functioning???
thanks for any help
TBT.1987 S4
thanks for any help
TBT.1987 S4
Basic Site Sponsor
Basic Site Sponsor
thanks for any help
TBT.1987 S4
thanks for any help
TBT.1987 S4
"Search" would be your friend.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
There's some great information here:
http://jenniskens.livedsl.nl/Technic.../MyTip1068.htm
I'd start by checking for power at the fan fuses initially and work your way along from there.
Hope this helps!
Hope this helps!
I’ll try to help you. Here are a few easy things to check:
As mentioned, dig in to the CE panel and confirm that all associated fuses / relay are good.
Next go to the front of the car and open the hood. Standing at the front look down at the bottom right of the radiator, you will see a connector. Unplug that and then turn the key to Run, both fans should come on.
If they don’t come on then next I would get a 12V battery and apply both a Ground and Power to each fan, directly; you’ll need to get under the car to unplug their connectors to do this unless you are much more agile than I am. If they don’t run at full speed it’s time to buy new fans. ETA it doesn’t matter which of the two prongs at the fan that you add Ground or Power to.
