89 S4 fuel injector harness
You can also get a new one from Kroon Wiring if you want to pay for a new one.
https://www.kroonwireharnesses.com/p...rsche-928-1989
Chronic Tool Dropper
Our vendors offer them. Try, in no particular order, 928 International (RL: Mark Anderson), 928SRUS (RL: ROG100), and Greg Brown (RL: GregBBRD). Some have sourced the wire and connectors themselves, but the aggravation of getting the wire colors right and building/testing is more than the cost of a full premium harness from these folks. In my opinion anyway.
84dizzy (05-09-2023)
I d not think that air filter base is correct for 87. Beginning with LH-Jet cars in 85 the base has a hole for an air temp sensor. Earlier cars did not have hole/sensor.
Mrmerlin (05-09-2023)
I'm not entirely sure why this was posted in this thread, but just FYI, the 84 Euros have a hole for an air temp sensor. And also, there is an upgrade for the sensor itself to a faster sensor that could make those engines that use the air temp sensor run more efficiently.
How to Modify Airbox Temp Sensor - Rennlist - Porsche Discussion Forums
Only LH2.2 cars use the air temp sensor in the air box. All LH2.3 (S4 and up) use knock sensors instead.
