Idle Air Control Valve for 85/86 also matches BMW?
So I was looking for a replacement Idle Air Control Valve and I came across a Ebay listening where it sells the part for my 85 Porsche 928 but also lists this part for a number of BMW's as well. It looks like the part and claims to fit my car, but I believe the 87+ Porsche 928's use a similar but not compatible Air Control Valve. A Valve for a BMW off Rockauto is still a lot cheaper than places selling a dedicated part for 85/86 928's. Even RockAuto doesn't list this part for Porsche 928's. He's not the only Ebay seller as I can find it even cheaper, though not Zinc coated. I do like Zinc coating. I feel this isn't common knowledge or the sellers are ripping people off.
Looks like it is the same original part, Bosch #0280140509. Fair warning, I found posts on various BMW forums also complaining about the Bosch part going out of production and not finding a reliable aftermarket piece. Buy the Rock Auto valve at your own risk!
dukenukemx (12-27-2021)
Get a Lowe replacement if anything. They seem to be at least half decent.
Also, the 85-86 ones are a wear part and do wear out. The 87+ ones do notIIRC but are not interchangeable with the earlier car's part.
bureau13 (12-28-2021)
Yea that's what I've read as well and probably explains why my engine has a bouncing idle. It has 210,000 miles and hardly anything looks changed in the engine. The 87+ do look the same, but what's different about them that makes them incompatible? Has anyone tried?
I'm less familiar with the 87+, but I think it's a spring-loaded valve that closes with no power, and the duty cycle on the positive pin is what opens it up.
dukenukemx (12-29-2021)
Basic Sponsor
Use the Lowe ISV - we sell it for $85 - yes it fits the BMW as well.
2 Year Warranty
2 Year Warranty
The following 2 users liked this post by ROG100:
davek9 (12-29-2021),
Both the 1985 – 1986 and 1987 and newer idle speed valves are controlled by a pulse width modulation (transistor) switch to ground. The positive voltage is a constant 12V.
Edit: I went looking for a thread from way back that did a deep dive into how these things work, but couldn't find it. The S3 ISV has an "open" and a "close" pin, and the LH sends pulses on these lines depending on whether it needs to increase or reduce idle. Maybe that could be considered PCM? I wouldn't call it that I don't think but it's still pulsing pins. It's just not the on/off duty cycle 2-wire connection that I commonly think of as PCM. I don't want to go into the weeds on terminology definitions...
The following 2 users liked this post by bureau13:
