Mounting washer pump hints.
79
Replacing the washer pump and rubber mounting feet no need to enlighten anyone that has done this how little room is available to perform this feat.
Is there any hints as to installing the rubber feet, is it best to “pull the nipple through the mounting bracket then fit the motor” or “mount them on the motor and try to pull through the mounting bracket” or a “combination of both”. My hands do not work as well as they used to!
Team Owner
put the new rubber pins into the base of the pump,
put some DC111 on the pin barbs,
have a helper pull the nibs through the fender well with needle nose pliers while you hold it in place.
NOTE test the washer pump before you secure it
