1982 928S Euro 5spd Moss Green metallic/Cashmere and Chocolate Brown
Bombshell!!! I am selling my 1982 928S Euro 5 speed Moss Green Metallic and Cashmere with Chocolate Brown interior. It has been my hobby and passion since 2010. Car is German market and was there 1982-1987 then it was federalized in Houston and then went to Florida where I bought it in 2010. I have gone through every system at least twice. 86,000 miles and asking $39,000 obo . I am selling it because I have metastasized rectal cancer (currently in remission after 6 rounds of Folfox). I want to move on to a 993. I have tons of spare and original parts that will be included. I am posting here first then will move on to classified ads here then maybe BAT. Car has German language on the warning lamps. List of work and things replaced or rebuilt follows…..ac compressor, dryer, expansion valve, r134a, all dash vacuum actuators and electric actuator valves, blower motor, Ice cold non leaking AC, spider boots, fuel injectors and seals, fuel pump, fuel hoses, in tank filter, fuel level sensor, fuel tank vent and vent hoses, radiator, steering rack, power steering hoses and reservoir, rebuilt power steering pump, rebuilt and calibrated WUR and fuel distributor, new fuel filter, steel brake lines and brakes rebuilt, new brake fluid recently, rebuilt clutch slave recently and new master cylinder and clutch master, new clutch hoses, new bushings in clutch release arm bushing and rear shift linkage bushing replaced, newer springs and height adjustable shocks installed, all failed suspension sealed rubbers addressed, recent 4 wheel alignment, brand new (2022) Continental Extreme Contact DWS 06 Plus tires all 4, Porsche Turbo Twist wheels 18x8 and 18x11, Magnaflow muffler with dual exhaust all the way, Innovate AFR with digital gauge in cabin along with extra digital voltage gauge, 5 speed transmission and clutch in good working order, all LED headlights and fog/driving lights, recent window tint, cruise control brain repaired and cruise vacuum actuator replaced with good used unit, repaint in original Moss Green Metallic in 2011, always garaged, all new leather interior ($10,000 spent), Sport seat and rear seat recovering, qtr interior panels, door card leather insert, arm rest, vinyl dash and pod recovered, all gauges work except for mileage meter, new carpet, beautiful Cashmere interior with Chocolate Brown, Alcantara steering wheel with green stitching, all by Classic 9 and Rob Budd, sunroof and door window switches and mechanisms totally rebuilt and work perfectly, Keyless remote door locks, rear wiper and rear defog working, Kenwood head unit with Bluetooth and high power,high quality sound system with 10 inch Pioneer sub, original M28/11 engine had foreign object cylinder wall damage in 1 cylinder, it was replaced with M28/12 block which is just the Automatic version of the high Output Euro 4.7 300HP engine, original damaged engine block goes with car also, the replacement engine was cleaned, new rings, resealed and heads were rebuilt in 2011. July 2022 Laso water pump , thermostat, Timing belt and tensioner pulleys, bolts and bushings replaced, new coolant and engine and power steering ATF oil replaced at this time, new rebuilt alternator recently replaced, ignition coil and plug wires replaced in 2013, new spark plugs installed in 2022, Both rear CV axles serviced and rebooted in 2021. 86,000 miles and selling for $39,000 obo. Pictures to follow
I’m
RennHarry (09-21-2022)
A comparison. Mine is a lot better than this one
Wow a great car I always liked this one. Best wishes for your recovery
gbgastowers (07-22-2022)
Worth every penny of this asking price (and then some) based on the service list and condition. GLWS.
Team Owner
GB thats a nice machine, interior looks brand new.
did the green wire ever get swapped for a new Bosch part?
What brand of shocks are on the car?
how many miles on the clutch and hydraulics?
did you swap in a new master cylinder for the brakes?
For you I suggest to look into a beam ray machine,
look up rife frequency list at altered states for more info.
PM me for more info
PM me for more info
Response to Merlin
did the green wire ever get swapped for a new Bosch part? (((I have a new one to include with the parts that will go with the sale-pic of green wire attached))
What brand of shocks are on the car? ((Boge-pics from my thread on this attached)
how many miles on the clutch and hydraulics? (((Hydraulics replaced-slave rebuilt recently and fluid replaced-extra slave rebuild kit included in sale/don’t know about how much clutch is left, came with car in 2010- works perfectly)))
did you swap in a new master cylinder for the brakes? (((Yes. In 2013. I also have a new brake booster that goes with car sale- brakes work great so not needed yet))))
New brake booster goes with sale
Boge adjustable-no leaks and working good
Belly pan from Jerry
New green wire goes with sale
PM me for more info
PM me for more info
Timing belt, thermostat, water pump and pulleys and bolts replaced last week (July 2022)
Pod recovered in stitched vinyl from Classic 9 done now
Crack in old pod
