79+ OB front rotors NLA
Rose Passion has them but expensive
Buy Porsche 928 (1978-1995) 928 4.5L 1978-82 Brake Disc Standard | Design 911
You can only get them from Porsche right now.
It's one of the reasons I got rid of them and stuck on 993 calipers and front rotors on my 81.
Thanks for responses.
I have found none available, for front brakes. The Rose Passion are the later model 32mm wide. Early are like 21mm wide. i did buy several rear rotors, while available. Caliper rebuild parts are available.
Good news is these cars get low miles, but some will need rotors eventually. I guess I will have to upgrade to 86ish, 32mm rotors, calipers, spindles...
I installed Big Blacks on my 79 with the 928MS caliper adapters and the ln 993TT Girodisc rotors fit perfectly.
Big Blacks with 993TT rotors (maybe 322mm if memory from 8 years ago is right)
Girodisc 2-piece front rotors
Did same design Powerslot e-coated 1 piece rear rotors with S4/GT/GTS rear calipers
Big calipers look and fit great in the 18" wheels
Basic Sponsor
928 351 041 09 certainly NOT NLA.
I have two in stock.
Porsche has 10 in the USA and 94 in Germany.
Terence (11-29-2022)
