1983 928 Auto leak
1983 928 Auto leak
Hey all,
need some more expert eyes on this one. Have a leak at the torque converter. Pours out especially on startup. Talked to Roger, he sent me a new torque converter gasket. Installed it, leak seemed to go away, but it’s either back or never left. Where else could it pour from?!?
There are multiple gaskets there with 1, 3, and 10 being your main culprits for leaks
You can get the part numbers here: http://www.autoatlanta.com/porsche-p...section=308-15
Order them from your favorite 928 suppliers
Otherwise you are going to have to remove that front cover to replace all of them aside from that one center seal.
Seems fixable. How is the rest of the project going? Did you get to do some test / tune before discovering the leak? Starting problem was bad LJet box, right?
BTW, thanks sending those test parts back.
Chris
Chris
The rest is pretty good. Actually have it up for sale now that that it “was” drivable. Problem did end up being the LJet. I’ve been driving it pretty regularly, just don’t like leaving transmission blood everywhere.
Team Owner
the leak is usually the pump O ring use DC111 on the O ring..
put vaseline on the snout of the TC so it wont burn up the bronze bushing
Got it put back together well enough to test it. Still leaks. Is there anything extra that would cause the torque converter seal to leak? (Torque converter not seated, not sealing?!?) It’s brand new, installed flush. See pics. It’s very hard to see where the leak is when the torque converter is installed.
have replaced 1, 3 and 10.
Team Owner
the rear end of the snout of the torque converter slides into the front pump then centers on a bronze bushing,
look inside the front pump after the TC has been removed
A little more history is required. When did the leak start? Did oil get low? did you replace the converter? is there unusual wear/scratches on the converter neck? did the converter feel tight after insertion to the transmission. Should spin but not be sloppy. Obviously you have experience with transmissions to take this on.
Did not replace the converter, does not seem to have excessive wear on the neck. Still feels "solid" when I put it in both times. Had to fight a little to get it fully engaged, but may have just been due to working under the car. Spins fine, can feel the pump meshing.
P.S. Didnt know Toccoa people knew what a Porsche was(joking). I'm through there quite often on 17.
Team Owner
your bearing looks OK and old,
just put a smear of vaseline on it before you insert the TC,
so it wont seize before the fluid gets to lubricate it
Also search into my threads on the same thing. I replaced pump/piston/TC seals… no leaks and a total newby on trans work here.
Lots of advice from Stan and Greg in my threads.
you’re removing the trans and standing it up-right like the shop manual says to do, for the seals/TC replace/reinsert, correct?
