The amazing 3 speed automatic transmission
Basic Site Sponsor
Basic Site Sponsor
Just finished rebuilding, installing, and adjusting a 3 speed automatic, in an early 4.5 liter car.
3 speed automatic, rebuilt and ready to install.
And wanted to mention how magnificent these transmissions function, when internally proper and adjusted correctly, in these early cars.
They upshift and downshift through the gears virtually without a flaw....completely dependent upon what you ask the car to do.
Almost like they are connected to your thoughts and desires...
Yes, I also enjoy the 5 speed cars (I enjoy just about every 928 model)....but I'm not convinced that converting an automatic to a 5 speed is the best ever "upgrade" to do.
Frankly, I'm a bit surprised that I can't ever remember someone going the other way....5 speed to an automatic.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
The following 7 users liked this post by GregBBRD:
8cyl (05-15-2023),
dimi5928 (05-16-2023),
freakngeek (12-23-2023),
GUMBALL (05-16-2023),
Porsche304 (05-15-2023),
and 2 others liked this post.
The following 7 users liked this post by Speedtoys:
8cyl (05-15-2023),
Adamant1971 (05-15-2023),
Denny Swift (12-22-2023),
Ed Petry (05-16-2023),
I always thought the 3 speed was the better trans. Even gear spacing and shifts effortlessly when asked.
It was better in my 81 than the 4 speed in my 89 S4 from my own experience.
8cyl (05-15-2023)
Those of us with 3-speed RoW cars know how pleasant of a transmission they really are. Fantastic box, and much stronger than the later 4-speed unit. If it were a choice between all three transmission options in the earlier cars I would only really consider the 3-speed or the 5-speed stick.
Sorry to ask a question on your thread but I have been asking about the adjustment on these boxes as I have an 83 in the uk and hoping the cable just needs adjusting as it doesn’t want to change up unless I back off the gas slightly.
I can only find information on the later box adjustment.
Thanks in advance.
Thanks in advance.
What RPMs do the 3 speed boxes turn at 90 mph? I would guess the 4 speeds have a better gear ratio for high speed cruising at a lower rpm. My 4 speed 84 Euro S turns 2,800 rpm at 90 which is where it's driven most of the time on trips. It also starts in 1st gear which I guess some of the later 4 speeds don't.
checkmate1996 (05-23-2023)
Basic Site Sponsor
Basic Site Sponsor
If you need more details, i can send yiu more pictures/measurements.
Basic Site Sponsor
Basic Site Sponsor
Thanks in advance.
Thanks in advance.
To start, you set the ball socket at the kickdown lever so that it fits directly onto the ball (no throttle applied) without preload or slack. You can adjust the ball or the lever to accomplish this.
When correct, from idle to full throttle, the level needs to move 33 milimeters.
The following 2 users liked this post by GregBBRD:
CliffH (05-16-2023),
Cymadesign (05-17-2023)
Basic Site Sponsor
Basic Site Sponsor
And like all things Porsche/Mecedes, factory parts have gotten very expensive.
The Workshop Manual covers this.
