Anyone have a Bosch Tool 000.721.926.60 to rent?
All - hard to swallow the cost of this tool and wondering if anyone has one they would be willing to rent out? I'm planning an intake refresh to start in a few weeks and getting everything lined up.
JT
JT
monkez (05-17-2023)
Basic Site Sponsor
Basic Site Sponsor
That tool is the absolute bomb, for that particular job.
Buy 2 and modify the second one so that fit easily over the injector connectors.
Eliminates connector breakage, loom and boot damage.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
Having such tool is indeed a necessity for an inlet manifold job . The purists will curse me but I found the easy workaround was to simply remove the spring clip. I ran this way for years and the connector never showed any signs of coming loose and if it did come off cold starts might be a bit tricky but one would instantly recognise what the issue was.
Several years ago I then revamped the harness and simply fitted a male/female junction outboard of the inlet manifold and the modern female Junior Power timer connectors have the easy release spring clip.
Now inlet manifold removal is a doddle for both the ISV and Idle switch connectors not to mention the injectors and every other connector.
