928 torque tube shaft size question
Does anyone know the diameter of the driveshaft and the number of splines? And if it is the same diameter/splines as the 944/968. Lastly, the length of the shaft?
Or if there is a resource I can find that info I would be happy to look it up myself if you have a link.
Why reinvent the wheel. Contact Constantine at Black Sea R&D. Problem solved. https://www.blackseard.com/site/
