3D Printed Ride Height Gauge
#31
@depami Hey man. Sorry about that. Work and then the holidays, I forgot to post my son’s print job of your files. I haven’t got the shark back yet to try it out but it has proved to be an awesome tool for the fiber laser.
Cheers,
#32
depami (02-09-2024)
#35
Ride Height Gauge Instructions
^^^^^ Glad to see there are some of these out there being used.
Just an FYI, this is how I calibrate the scale to read:
Cheers,
Cheers,
Schocki (02-10-2024)
#36
Hey, I stumbled on this post by accident while searching for a tool to help me adjust my Lotus Elise ride height. Do you know how difficult it would be to modify the tool to measure from 100mm to 135mm?
Also, I have always wanted a Porsche and hope to own one sometime in the near future so maybe stumbling into this is a sign
icsamerica (03-23-2024)
#38
Team Owner
can you print a set of the smaller speaker rings both of mine are missing
#39
What material to print this in?
Hi,
I submitted your files to Craftcloud for an estimate but I don't know which material to specify (they have 127 different ones).
Also do you have any recommendations for material colors to help make it readable?
Thanks,
Tom
89 S4 176k miles
Thanks,
Tom
89 S4 176k miles
#41
Choose any color you like but consider contrast for readability. Black on silver for the scale is always good.
#42
What is the correct Infill %
What Infill % should I use? The standard is 20%. Will that be enough or should I go higher?
If you haven't guessed already this is my first 3D printing project...
-Tom
89 S4 176k miles
#43
Also, the text could be printed right into the main parts but I made them separate files because they are the most likely areas to cause problems and there's nothing worse that the last 5% of a three hour print causing a bad part.
Once you really get into 3D printing you start to look at part design completely differently. I always consider support, wall thickness, resolution & detail, etc. when designing part to print. I also play with the direction of infill for some parts for various reasons. But then again, I can be a bit **** about details that probably don't matter.
Cheers,
