Automatic Transmission Cable
What does this do and does it look correct?
In the process of installing my rebuilt transmission and want to make sure I don't need a new cable.
Is there suppose to be something on the end of this??
Basic Site Sponsor
Basic Site Sponsor
My apologies, but the trolls/Forum moderators finally won, here.
I will never post anything helping people here, ever again.
As a matter of fact, I've be perfectly happy (overjoyed) if every single post I've ever made was completely removed!
I will continue to occasionally promote things, until they no longer allow that.
There may be tiny tidbits of information associated with those promotional items.
You can, for the time being, send me a PM.
Or, you can Email me at GregBBRD@aol.com
We will have a Website up, shortly.
I will, eventually, probably have a question/answer section, to go along with that Website.
Right now, sending any Email to the Precision Motorwerks web site is a waste of time.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
Basic Sponsor
Please add the year of the car to your signature as it really helps.
That is the pressure cable/kickdown cable. If you can expose the end of the cable at the gearbox end it will have a "hook" that attaches to a lever in the gearbox.
Change the O ring. Make sure the cable runs smoothly in the sheath.
Thanks Roger.
MCR - 1985 - 928 - 32v
Looks like that end clip is missing.
I'll email you.
I'll email you.
Basic Sponsor
I should of guessed that from the 85 in your signature.
The inner cable is available as a separate part 928 423 901 01. Can be replaced.
Team Owner
use DC111 on the new O ring
MCR 85 928 (12-05-2023)
Will do MrMerlin.
Cable has been ordered.
Thanks Roger!
Thanks Roger!
It looks like your cable end that connects to the transmission has the hoop on the end that the transmission lever can hook on to.
if the cable had something broken off, the new cable will have to be threaded into the sheaf. You’ll have to have a way of crimping/soldering the threaded shaft into the cable end that connects to the engine side ball socket.
MCR 85 928 (12-06-2023)
Damn Randy, long time no see. Getting back into the shark tank?
Team Owner
FYI from the original picture it appears that the cable end that connects to the arm inn the trans is just stuck inside the the plastic housing,
try tapping the end of the plastic on a block of wood.
