Removing/replacing cylinder heads
#31
The Parts Whisperer
#33
Are you saying you were driving the car and it was just running a little rough with several broken piston ring landings? I don’t see how it wasn’t just pouring out smoke with oil blow by and no compression/no start and GB says all the Euros pistons have broken ring landings? Does not seem possible. Gunar
#34
I reached out to Greg Brown to see about repairing it. He apparently does a nicasil spray coating on damaged walls, so hopefully that can recover my bores. Will learn more this coming week. I wonder what he'll try to talk me into though. I see he can build a 6.6L stroker out of these engines!
Best ways to get ahold of Greg/Precision Motorwerks are:
Phone: (714)-879-9072
Email: marybbrd@att.net (Schedule or talk to Mary and she will pass along to Greg)
Facebook: www.facebook.com/Precisionmtrwerks
#35
Thanks for his contact info.
#36
Unfortunately the email on the website is old and not the best way to reach out.
There is also a form of bat signal.
#37
I looked at nikasil plating and it is $3800! I'm debating:
1) sleeving the cylinders with iron sleeves
2) over-boring with larger pistons
3) swapping for another 4.7 block
Does anyone have experience with either of the first two options? Also, any issue using a later 4.7 block from a US car versus using the early 4.7 ROW block?
Thanks,
Camelman
Thanks,
Camelman
#39
Archive Gatekeeper
I'm in the midst of Nikasiling a block, it's a metric ton of work, both before and after the actual Nikasilling happens. So $3800 isn't surprising. I don't have any experience with sleeving. The challenge with overboring is finding 98 mm pistons. You could either find another 4.7 liter shortblock, or (alternatively) you could find a good 5 liter shortblock and build yourself a 5 liter hybrid. Probably a lot more good 5 liter S3 motors sitting around than 4.7 liter S motors.
