928 Forum 1978-1995
Sponsored by: 928 Specialists
Removing/replacing cylinder heads
Old 01-12-2024, 12:48 AM
camelman
camelman's Avatar
Default Removing/replacing cylinder heads
I’m pulling the heads on my 1982 928 S to replace all gaskets and seals. The engine is running a little rough too, which is what prompted this service. Am I an idiot for thinking I can do this with the engine in the car?
I’m cleaning and rebuilding everything else reasonable while I’m at it too, so this’ll be a big project. I’ve attached a pic of the current state of the car.
Stripping and cleaning as I go. Planning to re-plate all corroded parts, and replace the original wiring harness.
I love the Porken lift bars!!
Thanks,
Camelman
Old 01-12-2024, 12:55 AM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,571 Likes on 1,239 Posts
As Greg used to say:
1 head: Engine in car.
2 heads: Engine out of car.
Old 01-12-2024, 01:19 AM
camelman
camelman's Avatar
Rob, why is that? What makes it harder to pull both heads? Or is each head just a complete pain in the butt?
Old 01-12-2024, 02:13 AM
Rob Edwards
Archive Gatekeeper
It's not any harder to pull two than one, just takes more time bent over the fender of the car, and doubles the hassle during re-installation of the cam towers and their bolts. I don't want to trivialize the process of R&R'ing the engine but since you have to disassemble the whole front of the engine anyway, it's not really all that much more time to drop the exhaust, remove the hood, disconnect the AC compressor and power steering pump, and lift the motor out and work on it on a stand with all the room and leverage in the world.
The following 4 users liked this post by Rob Edwards:
BC (04-17-2024), Daniel5691 (01-13-2024), davek9 (01-14-2024), Mrmerlin (04-21-2024)
Old 01-12-2024, 02:21 AM
camelman
camelman's Avatar
Gotcha. I’ll look into it. I have a cherry picker at the warehouse already and an engine stand at home. I need to replace the oil pan gasket too, which will be a pain with the engine installed.
How tight is it to remove the engine from above? I just did this with a 944 and it was much tighter than I was expecting. I’d hate to bang up the engine bay on this car.
Old 01-12-2024, 02:49 AM
Rob Edwards
Archive Gatekeeper
Pretty straightforward, with the accessories off you have plenty of room- the tightest dimension is the lateral edges of the timing belt covers next to the engine crossbar mounting brackets but there's something like 1-2" clearance on each side. Disconnect the AC compressor from the block, the air pump, the PS pump, and the alternator, remove the exhaust , the lower bellhousing cover/ starter, separate the flex disc from the flywheel, undo the four upper bellhousing bolts, undo the rear crossmember-to-transmission mount bolts, pry the transmission/torque tube/hellhousing case rearward, remove the four engine mount bolts, and hoist that thing out of there. The reason the trans/TT/bellhousing have to go rearward is that the engine has to be lifted straight up the first 4 inches or so to clear the motor mounts. Don't forget the engine ground strap and whatever vacuum hoses go to the transmission on automatics.
The following 3 users liked this post by Rob Edwards:
davek9 (01-14-2024), RennHarry (01-14-2024), WestInc (01-17-2024)
Old 01-12-2024, 05:54 PM
camelman
camelman's Avatar
Thank you. I’m most of the way there, so should be a quick removal.
MCR 85 928 (01-12-2024)
Old 01-14-2024, 06:14 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,272 Likes on 1,261 Posts
Note on the 944 it’s easier to drop the engine out with the front suspension you do need the car on a lift to do this
davek9 (01-14-2024)
Old 01-14-2024, 02:22 PM
tv
tv's Avatar
nothing trivial about pulling the engine, especially if you have an issue with the bell housing bolts.
If I remember correctly You have to undue the tranny to body bolts in back and kick the driveline back a few inches to clear the flywheel out from the bell housing. That's a big deal!
Don't forget every time you undue a bolt you run the risk of fvcking it up, stripping the dusty aluminum. It will never be factory-snug ever again. It's OK for mechanics at a dealership they don't give a ----
Old 01-14-2024, 03:38 PM
Zirconocene
Zirconocene's Avatar
There's so much WYAIT if you have the engine out but the thing that comes to mind for me is putting new engine mounts in, if you haven't already. You may also want to rebuild and firesleeve your high pressure power steering hose. The HPPSH is not the worst thing in the world to do with the engine in the car, admittedly, but since you'll have ALL THE ACCESS...
Good luck
Old 01-17-2024, 03:16 PM
mark kibort
mark kibort's Avatar
its not a problem . i remember scot and i got his out of the car and on an engine stand in 90mins. makes it SOOO much easier to pulll those cam towers off... torquing the head nuts, etc.
Old 01-17-2024, 03:21 PM
mark kibort
sounds like moving the torque tube rearward is only required for autos? correct? (as ive never messed with the torque tube or transmission on the manuals when removing the engine)
Old 01-22-2024, 11:13 PM
hp18racer
hp18racer's Avatar
I never had to move the manual trans to pull the engine from my 1981. Doing it by myself was a 4 or 5 hour job out the top. Everything else you need to do is SO MUCH easier with the engine on a stand it is totally worth it.
Old 01-31-2024, 04:46 PM
Ad0911
Ad0911's Avatar
If you do the cylinderhead job with engine in the car you won't have that endless fun of doing other jobs while your are in there. A fairly classic pitfall I guess. I stepped into it and there seems to be no end of oddjobs to do.
Old 04-14-2024, 04:10 AM
camelman
camelman's Avatar
Default Bores and pistons are bad
I finally got time to pull the engine and cylinder heads, and confirmed the worst. All 8 pistons are broken between the first and second rings. The landings all have a similar section broken, so it's time for a bore and rebuild. From what Greg Brown says all of these 928S Euro engines suffer from broken landings, so I don't want to just find a replacement engine since it'll likely have the exact same problems. Half of the bores need help, and one bore in particular might not even work with a 1mm overbore. Can anyone point me to a good machine shop in the SF Bay Area that can work on these engines? If not, then any other suggestions are welcome. I also need to source pistons, but don't know where to look to find quality pistons that will last. Does anyone have a suggestion for that?
Also, what does experience suggest as a repair? Bore and oversize, or replace with an iron sleeve and use stock size?
The attached pics are the worst.
Quick Reply: Removing/replacing cylinder heads
