HVAC temperature control issue
Addict extrordinare
I decided to try and chase down a HVAC issue I've had for some time. The issue is that on AC I only get cold air when the temperature slider is full cold and I only get heat when it's set at full hot. I don't get any variation between the two extremes.
I've read a few posts on this and it seems the common issue is having an open circuit in the temperature sensor string. That's not what I'm seeing. I've disconnected plug 2 from the setting motor and measured resistance between pins 4 and 12. I'm seeing 4.2K ohms with the temperature slider full low and 5.2K ohms at full high temp. Could being 500 ohms high across the adjustment range cause the setting motor not to work properly? I'm thinking my setting motor at least partially works since I'm getting heat and cold at the max settings.
I dont recall the FULL procedure, but do you know if your ambient temperature sensor exists and is working in the system as well?
Kevin in Atlanta (02-05-2024)
Addict extrordinare
That sounds like a good place to start. I know the ambient sensor exists and the circuit containing both it and the interior sensor isn't open. That doesn't mean either of them are actually working properly though.
[QUOTE=snoz;19261113]I decided to try and chase down a HVAC issue I've had for some time. The issue is that on AC I only get cold air when the temperature slider is full cold and I only get heat when it's set at full hot. I don't get any variation between the two extremes.
I've read a few posts on this and it seems the common issue is having an open circuit in the temperature sensor string. That's not what I'm seeing. I've disconnected plug 2 from the setting motor and measured resistance between pins 4 and 12. I'm seeing 4.2K ohms with the temperature slider full low and 5.2K ohms at full high temp. Could being 500 ohms high across the adjustment range cause the setting motor not to work properly? I'm thinking my setting motor at least partially works since I'm getting heat and cold at the max settings.[/QUOTE
The max settings operate override switches so are not a complete test of the setting motor. Actually your resistance readings look ok as the WSM has range 3.7K-4.2K at 20C and if you are where your profile indicates right now it’s much colder in MO!
Could be the comparator circuit in the setting motor has failed. Easily fixed with a few new transistors but you could just open up the motor and test them first. All the ones in the board are NPN.
At an ambient temperature of 20 degrees C, you should see about 3,7k Ohm with the temp slider at cold. Moving it slowly to the full warm position, should show an uninterrupted increase to 4,7k Ohm. This is what mine showed back then when my temperature control motor quit on me (transistor failure).
Team Owner
first fail point IMHO is the connector for the external temp sensor in the LF fenderwell.
I suggest just cut it out and solder the wires together then heatshrink them.
NOTE test the sensor first to see if it reading properly
RTK (02-06-2024)
Addict extrordinare
I also plan to pull the setting motor as well and check those transistors.
My setting motor failed due to transistor failure.
Best to check the circuit with an analog multimeter, this way you can see any interruptions in resistance.
Addict extrordinare
Replacing the transistors seems to have fixed it. While none of the transistors tested as absolutely dead, one (maybe two) had a significant difference in resistance when testing between emitter to base and collector to base. One tested at around 25 MOhms on one side and 2 MOhms on the other.
Now I can see the setting motor gradually move as I move the slider up from full cold. I believe it's at about full hot once I get the slider much above the temperature in my garage. I reinstalled it and drove around. It seems to modulate the temperature in the car so I think I'm calling it good.
For future reference, I replaced four transistors. Two of them were BC327-25 PNP the other two were BC337-25 NPN. I cleaned what I believe is a potentiometer (square labeled Behr in the first picture) that helps the circuit control the position of the motor and a rotary switch on the other side of the motor.
Thanks for the help everyone.
Schocki (02-14-2024)
Had exactly the same issue with my temperature motor. Four new transistors and all is well since. Mine went to the full hot position in the middle of a hot summer in Spain.
The motor controls the heater valve too.
Easy fix to stay cool is to remove the motor assembly and bridge the heater valve, this way it's airways closed. Insert a cable between Pin 2 (red) and Pin 3 (black/red) into the smaller of the two connectors.
The flappy inside the HVAC box defaults to fill cold after the setting motor has been removed and the linkage was disconnected.
During summer in Spain I completely stop coolant flow to the heat exchanger. For this I installed a shutoff valve into the return line from the heater exchanger. Works great and turning the valve to "summer " can be done in seconds.
Installed
Hidden under the air filter box, but still accessible.
Installed
snoz (02-17-2024)
