Charging issues
Charging issues
Seeking some advice from the 928 experts on this forum:
My car is a 1987 S4 auto, 70,000 miles, well cared-for daily driver.
Recently while driving I'm seeing the voltage meter shoot up to 16 volts, also a high-pitched noise from the front of the car (probably the alternator) the central warning light flashes and tacho needle swings. If I pull over and restart the car the problem goes away for a while..then returns again. Normal charging at idle and driving is a little over 14 volts. I have replaced the voltage regulator and the condenser but the problem remains, the battery is new.
So, am I looking at replacing the alternator or is there another issue to be considered? The alternator is original afaik so probably 37+ years old. I live in Brunei in S.E Asia and all parts have to be shipped-in so a heavy alternator is an expensive purchase.
Thanks for any advice given. Joe.
Team Owner
Did you check the slip rings before installing the new regulator they should be smooth you might need to get them replaced a rebuilder can do that
What brand of regulator did you install it should only be Bosch
A battery can't take 16v for very long. You run the risk of damaging it or it exploding. I think it's new alternator time.
Why not try replacing the regulator built onto the alternator? It's not that difficult to do, would be less expensive, and could solve your shipping issue into Brunei.
Electron Wrangler
Then based on the same reasoning I'd tighten the the battery ground grounding bolt and/or replace the ground strap - its easy enough to do, and the strap is a well known intermittent failure point.
You can try wiggling the ground strap while the car is exhibiting the issue - move the end near the ground point and see if it changes anything, if needed get better access & wiggle the whole thing.
I'd just replace it anyway - I replaced the strap on my GTS many years ago - and it really needed it.
Alan
Alan
Schocki (02-28-2024)
When the problem occurs, measure voltage at jump post and at battery. If jump post voltage is high and battery is not, you know you have a connection problem.
Electron Wrangler
Alan
You are correct. I guess I should have stated the obvious, measure battery post to post, not from chassis. To me, that's a no brainer.
Electron Wrangler
Thanks for the suggestions. The ground strap was replaced a couple of years ago and all seems good in that area. I'll do the voltage checks when it next occurs. One additional issue I've just noticed; under hard acceleration the volt meter needle fluctuates like crazy (usually quite steady).
Electron Wrangler
So maybe not at the battery connections - but still sounds like possibly an intermittent connection somewhere else. Of course it could be intermittent within the battery itself (plate connections etc) - has it been changed since these issues started? can you try another?
Alan
Alan
