928 Forum 1978-1995
Sponsored by: 928 Specialists
HEATER BLOWER
Old 03-12-2024, 06:52 AM
Porschedrsmith
7th Gear
Porschedrsmith's Avatar
Default HEATER BLOWER
1986 PORSCHE 928 S2
Heater blower not working.
Relay seems ok.
If i put a jumper wire between pin 30 to 87 the blower works on all speeds.
when put relay back doesn't work.
Anyone got any ideas please.
Old 03-12-2024, 10:11 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,281 Likes on 1,265 Posts
Did you put a different relay in for the blower ?
Have you verified that all the other relays in your CE are the correct ones and in the correct positions?
Did you replace the X bus relay?
Old 03-12-2024, 01:01 PM
Porschedrsmith
7th Gear
YES I TRIED A FEW DIFFERENT RELAYS THAT I NEW WORKED.
ALL OTHER RELAYS WORK FINE.
WHAT IS THE X BUS RELAY.Thanks
Old 03-12-2024, 02:43 PM
Zirconocene
Zirconocene's Avatar
Scroll down for 1986: https://928srus.com/pages/charts
Looks like Relay 4 is your X Bus relay.
Cheers
Old 03-12-2024, 03:31 PM
Porschedrsmith
7th Gear
The x bus relay is ok
Old 03-12-2024, 11:07 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
to be clear,
have you verified that the correct part number relays are in the correct positions on the CE panel ?
Old 03-13-2024, 07:19 AM
Porschedrsmith
7th Gear
Yes all relays in right place
Old 03-13-2024, 10:48 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
NOTE disconnect the battery first.
OK look along the bottom edge of the CE panel for loose connectors,
and or individual wires that have come free .
next drop the CE panel and look for wires that might have gotten hot,
NOTE the insulation will have a satin finish instead of Matte.
Old 03-13-2024, 02:15 PM
Porschedrsmith
7th Gear
Front and back of fuse board all the wires ok
Old 03-13-2024, 09:34 PM
Alan
Electron Wrangler
Alan's Avatar
HVAC head unit unplugged?
Alan
Old 03-14-2024, 07:48 AM
Porschedrsmith
7th Gear
The HVAC is all plugged in. Thanks
Old 03-14-2024, 11:03 AM
Alan
Electron Wrangler
Alan's Avatar
The HVAC head unit is what turns on the Blower Relay - it is powered through Fuse #8.
Alan
Old 03-14-2024, 02:28 PM
Porschedrsmith
7th Gear
When i jump 30 -87 the four speeds work on the head unit doesn't that make head unit plugged in.
Old 03-14-2024, 03:29 PM
Kevin in Atlanta
Kevin in Atlanta's Avatar
First, are you getting voltage from the HVAC to the relay with the blower on?
Next, test the ground at the relay.
Either of those should point you in the correct direction.
Kevin
Old 03-14-2024, 06:52 PM
Alan
Electron Wrangler
Alan's Avatar
Originally Posted by Porschedrsmith
No it proves rather little about the head unit - it does mean the blower speed switch is plugged in but that is a completely separate connector from the main HVAC one that turns the relay on - check the fuse #8 - that was my point, A blown fuse would stop the relay turning on normally.
With the Blower Relay (X) out you can see if pin 86 in its socket is at 12V with Ignition on and HVAC head not turned off (blower switch doesn't matter), you can also test that socket pin 85 has continuity to ground. These are the only things needed to turn the relay on. Likely you don't have 12V on 86. NB For this year the X-Relay (IV) is not a factor
Alan
Quick Reply: HEATER BLOWER
