Looking for some clips
I am looking for a few of these little clips. They are not listed in PET. They are part of the radiator faring/duct assembly and hold the two pieces together at the bottom edge. I’m hoping to find a suitable replacement. They measure about 20mm wide and will pinch something up two 3.5mm thick you can see some warping of the plastic and I am hoping to seal it with a few more clips.
here is the shroud assembly for some context
was just cleaning the shroud and flap motor assembly on the bench and was just about to look for those very clips on PET.
so have just gone hunting through my box of clips to find something to fit mine
pictured clip is 92855112302, and is an excellent tight secure fit, just need to cut off the not needed curled over part of the clip.
not exactly cheap, but i am sure Mark at 928inter will have a box full of them
cheers
Phil
cheers
Phil
Michael Benno (03-24-2024)
Inventor
Careful application of a heat gun should minimize that warping. Worked in the heater box.
You're not alone: https://rennlist.com/forums/968-foru...-radiator.html
ETA: I had to step away for just a bit but, for those that don't want to click thru, the parts reference on the 968 are 477 819 212, 999 591 342 02, and 999 591 342 03. I haven't looked up pictures on Google to see what's right, but they are at least called out on that particular PET document.
Cheers
Cheers
