Wintertime is not all bad
The following 14 users liked this post by paalw:
928 GT R (03-29-2024),
Bertrand Daoust (03-28-2024),
Brent A. (03-28-2024),
chakka (03-27-2024),
CliffH (03-28-2024),
and 9 others liked this post.
The following 5 users liked this post by paalw:
BIMMERMIKE (03-27-2024),
davek9 (03-28-2024),
JBT3 (03-27-2024),
Mrmerlin (03-27-2024)
Nice work and your car looks fantastic!
Team Owner
Wow thats a super clean machine,
it looks like you have most if not all of the cosmoline removed,
thats quite a feat.
I was going to suggest that you recoat the front rotor hats and the rotor edges ,with some hi heat gray
same as the rear rotors you have that are E coated.
this will prevent rust and keep the wheel hub package looking clean after its been washed.
Also I would suggest that you lower the RMB tips a bit to add clearance to the PU cover,
otherwise over time the PU cover will deform and may melt on the tips.
NOTE you could also add a few pieces of aluminum duct tape to the PU cover,
no one will see it but it will protect the paint.
Good Luck with the care and feeding of your machine !
thats quite a feat.
Delicious!
And YES it looks clean enough to eat off of!
Congratulations and enjoy it in good health when spring arrives.
