Battery Ground Cable (Porsche) 89 S4
Electron Wrangler
Contact mark @928 International and get a nice used factory one that already has the bends in it or run down to Tractor supply,they usually have them in different lengths. Lost a ground strap on my Jag while on a road trip, picked up a braided cable type for 9 bucks,but it was a short one.
Alan
Team Owner
NOTE I would suggest that you dont add a ground cutoff switch,
as it will create more issues with the charging system.
NOTE of the 928s that I have fixed 6 of them all had either loose or corroded or broken cut off switches, wire connections.
2 of these caused the car to be disabled while it was being driven.
Or better yet wait till you find one of these devices thats filled with water from a leaking hatch seal
That data point given,
it is more common than you might think to have a loose or dirty battery connection.
Using the ground strap and wingnut gives the operator the chance to inspect this connection every time its connected.
NOTE in every case I removed the cutoff switch and restored the system to stock configuration.
I would not buy a used Porsche cable in this application - they deteriorate with age and can become intermittent before total failure. An aftermarket (slightly longer) cable with a heat shrink sheath sealed with adhesive at the battery end is the best bet. Personally I used a clear adhesive heat shrink sheath (‘clearly’ not stock) - it allows monitoring of the health of the woven strap - which is normally hidden anyway. This also allows for a battery switch in the ground line located behind the tool panel at the ground point.
Alan
Alan
Good to know. Thank you for the been there done that life experience.
So maybe the battery tender in the garage is the smarter solution to the "Porsche Battery Drain".
I'm looking forward to having my battery and spare tire tucked away. The jump post might be the best option for the tender.
Pick your size here and get some 1.5" shrink tubing and make your own? Pick the 2 gauge:
https://www.delcity.net/store/Ground...18655.h_180825
Electron Wrangler
Originally Posted by Jason89s49372874
Alan, if not concerned about originality, why not use a woven bare metal strap? Why the need to sheath? These woven ground straps can be ordered to length, are easy to find, and were used for decades on American cars.
The 928 battery is much more enclosed than a typical american car...
Alan
Electron Wrangler
Switches I'd recommend are Blue Sea Systems (likely too large for this location) and genuine Hella >500A (warning there are huge numbers of cheap & nasty copies). You'd need to fabricate a bracket to bolt the switch to the ground point and make the ground connection. If you aren't confident you can do it well - best not to do it at all for the reasons Stan noted.
Alan
Basic Sponsor
Here is a picture of the end of the Porsche supplied ground strap and my own aftermarket strap.
The problem with the Porsche strap is the first 3" of BOTH ends are solid with solder. This makes the strap rigid and not conform to the bends required to fit a 928 battery in a 928 battery box.
https://928srus.com/products/copy-of...-strap-porsche - if you do not want to make your own ours are $39.95
The aftermarket strap flexs right from the joint both ends.
My solution:
I bought a longer and a shorter ground wire, insulated them with glue-infused heatshrink, mounted the switch in the corner beside the sparewheel. Easy access and works great. The red switchtop is removable when switched off...
Just get a strap from Del City and spray with, …. FlexSeal.
You can mask off the ends as needed. Good enough for a boat, who’s to say it won’t work for a strap in the trunk. The stuff comes in many color too.
@Alan, I've never seen a battery cutoff switch (shown in Post #9) configured in such a way before. When I was having a current drain problem with my '89 S4, I was looking for a battery cutoff switch and only saw the ones like you'd use for marine applications. In contrast, this one looked slick and well made. Would this one have the same potential problems as described by @Mrmerlin in Post#18? Don't know...I went the battery maintainer route.
What you described in Post #24 is a good plan for a cutoff switch design if you get the right components. However, the battery maintainer still seems a cheaper alternative (if you can't find/fix the current drain).
Team Owner
If you have a current drain doesn’t it make sense to remove the battery from the circuit or would you rather put it on trickle charge so you now have two power sources feeding a draw ?
you might have missed the point of a battery cut off adding more connections to remove power will increase the possibility of a failure of one of these connections
I have seen this happen more than a few times
IMHO the best thing you can do is keep the system as simple as possible Isolate the battery by disconnecting the ground strap
Charge the battery every few months with a 6 amp battery charger.
this should give your charging system and the starting relays a long life
You just have to be smarter than your ground strap
