Spark Plug Wire Order
Installing new spark plug wires on 1982 4.5 with new distributor cap. I have the pdf workshop manuals but can’t find the info. Do you just match the dist cap number to the cylinder number? If it’s more complicated than that, can you direct me to where the information is in the workshop manual?
thanks
thanks
thanks
thanks
Zirconocene (04-10-2024)
Team Owner
This should be pretty easy first put the engine to TDC.
Verify the cams and crank are lined up,
pull the cap and see where the rotor is pointing.
It should be at the hash mark in the distributor body,
this will be #1 then take your 27 mm deep socket,
and turn the engine CW while looking at it .
Note the direction of the rotor is turning.
Then you can make a diagram for the cap by using the firing order on the cam tower.
NOTE the cap will only fit onto the distributor one way.
