CORRECTED: RMP dependent driveline vibration that stops when clutch pedal is pressed
I am getting a shuttering RPM dependent vibration rather badly and certain RPM"s are considerably worse Issue goes away when the clutch pedal is depressed. I understand I should: Find the RPM range where it is worse, look to see if my TT bearings have migrated. Check for a broken clamp.
It is not clear to me if it is coming from the front or the rear of the car. it seems to be all along the center under the car. Could motor mounts or transmission mounts cause this issue? What about clutch components although the two discs are relatively new. Could it be a finger on pressure plate? is it necessary to have the clamps taken somewhere to be spun on something to be sure they are perfectly balanced? if that is even a thing? or should they not have changed? Any thoughts on where to look is appreciated.
A few years a go I installed a rebuilt TT as I was getting two new clutch discs and had severe wear on the shaft splines. At that time I also replaced the front and rear shifter cup/couplers and am using Greg Brown's stub shaft.
P>S> I have modified this post and title and left Mark at 928 Intl. a message. I sincerely apologize that my first post was disparaging
Are you sure it is the bearings?
Bearings tend to squeal - that you use the term "clunk" suggests it could be the damper that has come loose? Does this happen when you accelerate/break or is it continuous?
crushingday (04-11-2024)
Well I guess "clunk isn't the right descriptor. It shakes and the shaking is more pronounced at certain RPM's. I have edited my original post to clarify and remove the word "clunk" with "vibrate". It all goes away if I depress the clutch pedal. Smooth sailing through the RPM range if the clutch pedal is pressed.
I always recommend @Michael Benno 's nice write up on replacing TT bearings: https://benno928.wordpress.com/2022/...e-torque-tube/
Someday I'll have enough of my own fires put out to be able to do this myself, not from need, but from desire.
That said, reach out to Mark Anderson directly, as well, I'm sure he'll be able to help.
Good luck
Good luck
Basic Sponsor
Have you talked to Mark out of courtesy. I am sure he will help as best he can.
Sorry you are having an issue. I have sold plenty of Marks TT's in the past without issue.
The following 2 users liked this post by ROG100:
928FIXER (04-11-2024),
Call RPR Automotive in Brooklyn Park,MD. They are a father son team that did mine, 1985 928S, installed super bearings and used the Ritech clamp from Roger. They are inside the beltway on Belle Grove Rd, IIRC. They’re located inside the beltway. Also replace shocks and coil overs in rear.
Good fellows that are honest, and tell you straight up what’s going on.
I’ve dealt with Colin, son and John is the pop.
That said, reach out to Mark Anderson directly, as well, I'm sure he'll be able to help. Thanks for the link .
Good luck
Good luck
You can open the inspection cover on the bell housing and take a look in there.
Although possible that the TT bearings have gone south [again] I would think it somewhat unlikely unless something has excited premature failure.
Are the symptoms identical to the original failure you experienced thus causing you to believe the problem is the TT bearings again?
The following 5 users liked this post by UKKid35:
Adamant1971 (04-11-2024),
crushingday (04-11-2024),
Geo55 (04-11-2024),
Mrmerlin (04-11-2024)
A little quick on the trigger finger there. Before condemning the TT repair get it out and verify what failed. That said... Even if the repaired TT bearings did fail, I'd be satisfied with 7 years from a specialty remanufactured part that was made available to a niche market.
Team Owner
you can use a bore scope to figure out if the bearings are migrating,
thus you wont have to remove the bell housing,
and only the inspection plug at the rear.
Replaced the TT in my GTS in 2005 at 100 kmiles with a rebuilt unit from Mark. No issues whatsoever, car is currently at 180 kmiles.
Give Mark a call first, he has been supporting the 928 community for years.
I just left Mark a message. How do I delete this thread?
The rebuilt torque tube was due to worn splines and not a bearing failure issue when i replaced it
Yes in hind sight i have should have done just that. My apologies to 928 International and Mark personally
Agreed I will do further research and pin point the issue
thanks Stan
Yes I know Mark has been a trusted vendor and supporter.
thanks Stan
