Transmission flush
8th Gear
Transmission flush
I have a 88 S4 with 90K and not sure about the PO maintence history on the car. Car is great with no problems but I would like to do a BG trans flush. I have been told that it might not be a good idea if you don't know the service history, that it might dislodge some crud and cause problems.Is it best to just do a fluid change or the flush. Any thoughts on this ?
Tazz,
Empty the gearbox and the converter -Remove the oil pan - Disconnect (open) one of the oil hoses to the cooler and blow with reduced air (max one Bar) for emptying the cooler - Shift the filter unit
Regards from Erik in Denmark
Hi,
as Erik suggests it is better NOT to "flush" the Auto trans. Drain the pan and TC and replace filter. Replace the ATF (Dexron 3) - Castrol's synthetic Dex 3 ATF "Transmax Z" works well in our cars
Best regards Erik!!!
Regards
Doug
Regards
Doug
