Hm... bad relay?
Deer Slayer
Hm... bad relay?
My car has a gremlin. Surprise, surprise.
Sometimes my power wondows and sunroof work when there's no key in the ignition. I suspect they shouldn't. No other accessories do this.
Sometimes, they only work when the key is in and turned a notch or 2. I suspect this is the correct config.
So: something is intermittently allowing power to the windows and sunroof.
Relay? Ignition switch? Other?
I've pored over some diagrams, none the wiser...
Rennlist Site Sponsor
From the 1985 Service Information Booklet W K D 491 721:
Power Windows
USA cars have a power window circuit which is activated via a special relay (VI - yellow print) .
Power window motors can still be operated after turning off the ignition and closing the doors .
This operation however is stopped when a door is opened . Power window motors can then be operated as required only after turning on the X contact or ignition .
In R . o. W. cars the windows can be operated with the doors open (no change in comparison to 1984 models) .
In perhaps a bit plainer English:
For USA cars after 1985, you can operate the windows and sunroof after you turn the ignition switch off - until you open a door.
For R.o.W cars, you can operate the windows even after you open a door.
If your windows will work on a USA car with a door open:
- You may have a bad door switch (the system doesn't know a door is open).
- A relay may be sticking shut (Relay X - I think)
- Someone has changed the wiring.
Power Windows
