928 Forum 1978-1995
Sponsored by: 928 Specialists
New Product - DEVEK electric fan conversion for early and SC 928'ers
Old 02-10-2005, 07:02 PM
  #31
Ketchmi
Ketchmi's Avatar
Hey Shane!
I used to run a 2500cfm Perma-cool in the factory shroud and it just didn't cut it down here during the summer in traffic. It does get a bit warm here, wish it would soon!
Shhhh about the driving light idea, someone may try to do it cheaper. (LOL)
Actually mine work great but it just may not be economically feasible. With the labor and parts I need to manufacture, the cost may be too much for reasonable resale. But hey! I can spot deer at about a mile!
I will weigh our fan system as soon as I can locate our scale.
Marc, we have a Lear Jet pilot working here part time that's been giving me pointers but I'm still qualifying on the ground. Have you heard about the new road course going in out here? 4.2 miles with elevation changes! WOOOOOHOOOOO! 370 acre's with two seperate 2 mile tracks that can be combined. Supposed to be "World Class" by all standards and open this fall.
Dave
Motorsport
Old 02-10-2005, 09:49 PM
  #32
touque
touque's Avatar
for us pre-S4 types, what volume of air (cfm) does the stock, pulley-driven fan suck through the radiator?
Old 02-10-2005, 09:51 PM
  #33
Fastest928
Fastest928's Avatar
Hard to tell, to many variables including clutch condition ...but can tell you that it was not enough to cool a stroker. this setup works fine.
Old 02-11-2005, 01:28 AM
  #34
CT928
CT928's Avatar
This thread's come along at the perfect time.
My car has the belt adjuster for the fan rather than the air pump. And this has just failed.
I want to upgrade to electric fans because the belt driven fan can't cut it here in summer when the temperature is 50deg C plus.
Does anyone have any pictures of their electric fan mods installed. (Other than the Devek one)
Old 02-11-2005, 02:13 AM
  #35
SharkSkin
SharkSkin's Avatar
More pics and details here
Old 02-11-2005, 03:08 AM
  #36
PorKen
Inventor
PorKen's Avatar
I hadn't seen that before, nice job + writeup, Dave.
Old 02-11-2005, 04:53 AM
  #37
drnick
drnick's Avatar
Default twin electric fan conversion
this plugs into the stock harness and is switched by the signal used to drive the accessory fan on the front, which is removed. they are two kenlowe (UK) 13" and rated at 1380 cfm and about 25A each. they do make a hell of a racket when they switch in!
Old 02-11-2005, 08:55 AM
  #38
CT928
CT928's Avatar
How did you secure the Kenlowes to the radiator?
Are normal bosch relays apable of handling the current needed by the fans?
Old 02-11-2005, 09:14 AM
  #39
drnick
drnick's Avatar
they come with brackets that arent 928 specific but can be adapted without too much trouble. they have there own relays and thermostatic control included, but the wiring is not that complex. these are the same relay (i think) as is used for the fuel pump.
Old 02-11-2005, 11:31 AM
  #40
WallyP
Rennlist Site Sponsor
WallyP's Avatar
Extensive testing by a major auto manufacturer showed that fans are much more efficient when the blades are mostly outside (behind) the shroud - i.e., the fans work better as a combination of axial and centrifugal flow.
Old 02-11-2005, 12:18 PM
  #41
SharkSkin
SharkSkin's Avatar
Thanks!
Old 02-11-2005, 12:27 PM
  #42
sublimate
Gluteus Maximus
sublimate's Avatar
I've seen this said before (perhaps by you) but I'm not quie sure what it means. Does it mean that the ends of the blades are covered by the shroud so that the only air they see comes outword (radially) from the center of the fan? Do you have any pictures or drawings?
Also it seems there is a bit of a tradeoff. Covering some of the fan with the shroud may make the fan work better, but it would decrease the natural air flow when you're driving. As such you fan would have to run at higher road speeds than with a smaller shroud.
Old 02-11-2005, 12:33 PM
  #43
CT928
CT928's Avatar
Sharkskin,
I read through your page on the fan installation(impressive) but you don't say if you removed the viscous fan or not?
Old 02-11-2005, 12:36 PM
  #44
Bill Ball
Under the Lift
Bill Ball's Avatar
By centrifugal do you mean the fan is throwing air to the sides as well as pulling it through (axial), and being inside a shroud restricts that? Oh, so Dave A. might want to try mounting the fan on the rear of his aluminum ring, if there is clearance. Ah. oops! I see Dave A's is a pusher. That changes things, doesn't it?
Oh, and I see Devek appears to have taken this into consideration when mounting the fans in the new setup.
Old 02-11-2005, 12:38 PM
  #45
Mark
Mark's Avatar
Just my $.02...
THe new Devek fan kit looks SUPER nice.
Nonetheless, some time ago - I removed the belt driven and front factory electric fans completely and installed a pair of (I think 16") Hayden fans in a push-pull configuration. In normal driving, it RARELY goes above the 1st indicator mark, and even during Florida summer heat DE's and AX's does it get to the 2nd mark. IIRC - total cost was around $150 and 30 minutes of my time. Doesn't look NEAR as nice as Marc & Co's new product - but gets the job done well!
Quick Reply: New Product - DEVEK electric fan conversion for early and SC 928'ers
