Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 928 Forum
Sign in using an external account
Register Forgot Password?
Search
This Rennlist Forum is sponsored by      ....dedicated to Your Porsche 928
Thread Tools Search this Thread
Old 04-01-2005, 12:16 AM   #1
moon928
User
moon928's Avatar
Default Smells like Band-aids???
Every once in a while I will get a hint of burning rubber in the cabin of my 88 S4. It is not very strong and smells more like band-aids than it does burning rubber, but no matter what the smell cant be good for my ride. I do remember someone else having a post here describing the same odor, but I cant find the post anywhere in the archives.
I have driven my car about six times this winter and I have noticed the odor seems to come and go when I am running the heat. I thought at first it could be my blower motor, but I am not entirely sure because I still get the band-aid smell after I shut the blower off, and run the heat only. The smell does go away when I shut the heat off.
Does anyone have any thoughts as to what it could be?
Moon
To remove this ad, register today or login if you already are registered!
moon928 is offline   Reply With Quote
Old 04-01-2005, 01:13 AM   #2
deliriousga
deliriousga's Avatar
It might be the infamous "Y" connector. There's a description and fix for the problem at http://www.nichols.nu/tip181.htm It usually smells like gas or oil, but I'm sure the smell depends on what's leaked into that area. Check it out, could be a cheap fix.
Good luck!
deliriousga is offline   Reply With Quote
Old 04-01-2005, 09:29 AM   #3
Garth S
Garth S's Avatar
Little critters had previously taken winter residence in the engine side of the heater core box: unusual odours accompanied springtime driving - although 'band aids' is not the most apt description ....
Loosen the rubber bellows between the blower fan and the plenum/box if you are curious for a peek.
'96 993 C4S Midnight blue , Bilstein HD, M030 bars & turbo springs, FPB, SSK, wide ovals w. LPMM, 8"/11" 'hollows',or RS-GT's Schnell brace
'80 928 Copper brown 5-sp, Konis, euro S springs/brakes, CS wheels, S4 wing
Garth S is offline   Reply With Quote
Old 04-02-2005, 06:09 PM   #4
david928
User
david928's Avatar
Send a message via Yahoo to david928
A couple of times after parking the beast I saw some "oil smoke" coming in through the console. It hasn't happened for a while, but will follow the above suggestions if it happens again.
david928 is offline   Reply With Quote
Old 04-02-2005, 08:07 PM   #5
Ispeed
Super User
Ispeed's Avatar
could be smokin' credit cards... they usually take some heavy damage from the 928.
Ispeed is offline   Reply With Quote
Old 04-02-2005, 09:04 PM   #6
moon928
User
moon928's Avatar
Garth- thanks for the tip. I wish you could smell it you wouldnt believe how much it smells like band-aids.
Carl- I hear you there. It never fails everytime I set money aside to do the things I want- like new tires- the car has something else in mind.
Moon
Paid Advertisement
Tags
aid, aids, band, bandaid, bandaide, bandaids, car, coming, discussions, heater, motor, oil, s4, smell, smells
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright ę 1998 - 2007 Rennlist.com
Advertise on Rennlist - Privacy Statement - Terms of Service - Jobs
Emails & Contact Details
