Picture Twin turbo setup
How is the spool up time? Looks like an awful long distance to run the exhaust to the turbos. They are small units so this may help, but i would think lag must be an issue for street driving.
It looks like about a foot and a half to me, could be more depending on the location of the exhaust ports. About the same as my 94. The newer turbo designs are running considerably less distance to help reduce lag. Just a thought.
Fleet of Foot
Can't help but wonder if it is possible to insulate that hood enough... I have visions of a meltdown under heavy use, turbos glowing red-hot, etc.
They make insulator jackets that cover the turbos that can be used. It looks like the turbos were ceramic coated for heat. Although I was thinking the same thing myself and the setup is very close to the intake and radiator which is going to burn up those turbos rather quickly. There are also no intercoolers and IMO you may gain hp but the setup will be short lived, although the work is impressive. Power is great but reliability is most important in my book.
Actually with another look the turbos are water cooled and it is possible they placed intercoolers in front of the radiator which would make a big difference.
I would be interested in some specifics of this set up.
Captain Obvious
Super User
Super User
COBALT,
Try to look a little closer next time. It is clearly visible that the turbos feed into an intercooler. I looks like it's an air to air unit.
The blow off valve is located right at the front of the the engine. Right as the intake pipe turns towards the engine. These turbos don't have an internal waste gate. They are
located right after the meeting of the tubes with the collector pipe. Very visible on the right bank.
The inverted long tube headers are a very nice way of installing the turbos. However cast iron manifolds are more durable but they flow alot less than tubular headers.
This picture must have been taken before the installation is compete. Two of the left bank spark plugs are not connected (they are right behind the collector pipe) and at least one of the right ones isn't connected either (wire end located right on the turbine housing, next to the alternator pulley). Also, the front two coils don't have the spark plug wires connected either.
In all, it is a very nice, clean and compact setup.
Originally Posted by Imo000
COBALT,
I was not saying that the workmanship or the work in general was not impressive. It is top notch. Based on what I have observed I would expect some lag to be generated by this design. I may be wrong and was just curious to how it actually performed.
Under the Lift
Heh, heh. Even little old me noticed the plug wires dangling. Wonder how long they last anyway. Wouldn't it be like a blast furnace under the hood?
Where can you have intake pipe fabricated? I'd like to have some of that red stuff on my Supermodel.
