Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 928 Forum
Sign in using an external account
Register Forgot Password?
This Rennlist Forum is sponsored by      ....dedicated to Your Porsche 928
Thread Tools Search this Thread
Old 07-08-2005, 04:19 PM   #16
rob rossitto
User
rob rossitto's Avatar
FWIW, I used elgins to regrind my GT cams - .020" over stock gt, w/968 valves, stock GT springs/lifters and it seems to idle fine, but it does leave big black marks on the driveway (no dyno #'s, but melting a 18/285/50 for over 30' w/ 1/2 throttle pretty much says it all for me)... I changed so much stuff, I really don't know how much is just from the cams, but elgins thought about 25-35hp at the crank was a reasonable expectation for that grind on a 6.4L motor, at 3k-5500k rpms...
according to elgins, anything over that and you'll have issues w/stock springs/lifters and idle/street use w/an AT 928... they also have some custom 928 cam indexing jigs that help keep timing spot on... $700 and 2 week turn around included nitriting... nice guys too!
hope this helps...
you'll also have to make your valves the right ht for the new cam specs, so be ready...
rob rossitto is offline   Reply With Quote
Old 07-09-2005, 04:16 PM   #17
m21sniper
m21sniper's Avatar
Lag: "I don't care what the magazines say,"
Well that's a very telling statement...
"I've seen many many many dyno sheets from all over the world, and every single stock Z06 dynos between 340-355 at the rear wheels (..DynoJet). EVERY SINGLE ONE."
A 15hp spread on a motor that's only in the mid 300hp range. Not exactly what i'd call particularly accurate.
As power increases so will the margin of error.
This is why 5000hp top fuel motors(let alone turboprops or locomotives) don't even bother with dynos. The margin of error would be ridiculously large.
"Just because a magazine may have 'discovered' some unscrupulous shops doesn't invalidate the rest of the shops that run their dynos correctly."
No, but there is no denying that there's an inherent innacuracy, as witnessed by your claim that stock Zo6s all dyno within 15hp of one another using the same exact settings on the exact same model number dyno.
"'Wildly overrated IMO'?? That's funny! Just curious, have you even dyno'd a car before?"
Sure have. I was a Pa licensed emisions technician for 5 years, Pa uses a chassis dyno for emissions testing.
This one:
"Nonetheless, that's just your opinion, and you're entitled to it; however, I disagree. A timeslip is GREAT stuff, but there's way too many variables from run to run versus a controlled SAE dyno run."
You simply go by your best ET and best trap speeds, and average the two with the appropriate conversion formulas. It's a very accurate measure of actual useable power.
To me, the only way a dyno is truly useful is if you're using the same one all the time, as Greg stated. It may be off by a set %, but at least it will be 100% consistent in it's error.
But i digress, i don't want to hijack this fellas thread.
m21sniper is offline   Reply With Quote
Old 07-09-2005, 05:07 PM   #18
Lagavulin
User
Lagavulin's Avatar
Wow, it's pretty obvious that you're just shooting from the hip.
It is no 'claim'; it's a FACT! GO LOOK IT UP!!! And while you're at it, go look up the factory horsepower numbers of a 2001 Z06 versus the 2002-2004 models.
BTW, are you not familiar with engineering tolerances, and that one engine from the next will not put out the same amount of horsepower? This is getting ridiculous...
This one:
No offense, but I've had my car smogged many times by an emissions tech who 'drives' the car by following a curve on a monitor, so it's pretty safe to say that the two are different, thus, you have never dyno'd your car on a chassis dyno before to obtain rwhp numbers.
I'm not disagreeing with your statement; I simply said an SAE dyno provides a much more consistent measurement of rwhp due to the lack of the infinite amount of variables all the outdoor tracks are faced with.
Lagavulin is offline   Reply With Quote
Old 07-09-2005, 05:22 PM   #19
Fastest928
Dynos....ahh, my favorite topic!
So many factors, so little time!
To minimize the factors, jsut stick to SAE numbers. Each dyno manuf has doen their best to integrate the SAE CF standards and they are all VERY close. The DynioJets may not be tolerenced to the nth degree, maybe +/-3% one to another, but clsoe enough that we can make good judgement o perfromance "trends".
One thing I will state is a fact. Put two 928's on a dyno, the one with the most average hp under the "important" part of the curve (as defined by the trans ratios and "used" rpms) will win the drag race every team.
Drag racing is considerably too driver dependent...and I know I suck at it Made three runs, barely made it home on a shredded clutch......car never smelled the same
I have also seen at Sears on Wed nights and watched one car, three drivers, and every time was different.
Marc
Marc
Fastest928 is offline   Reply With Quote
Old 07-09-2005, 05:26 PM   #20
Fastest928
Rob,
That is amazing pricing on the cams! Damn ... I cant touch it.
When are you dynoing the engine ... sounds like it should make about 400 - 425 rwhp based on components.
The best we ever made with stock GT cams was 440 rwhp. Most end up at 400 +/-15.
Marc
Marc
Old 07-10-2005, 05:58 PM   #21
rob rossitto
User
IMO, I think thats a very overlooked point!! and don't forget true atmospheric conditions and trans issues can wreak havok on reporting available NA power just as much... add them all up and... IIRC, the type/condition of the dyno also affects the type of results that are measured/reported....
I don't trust everything the mags and OEMS report - ever since 0-60 became the "rolling start 0-60", it just got too wierd for me... kinda like unemployment numbers only counting those currently elgible for unemployment benefits..
Quote:
Rob,That is amazing pricing on the cams! Damn ... I cant touch it.
Marc
I wish $700 was the real total for me!! pricing was for regrinding/nitirite only- you gotta provide the cams.... IIRC, my used gt set was $1200... so it's really $1900 w/out any trade in/core set/etc... do have a decent set of 85 cams "laying around" though, so depending upon what I get for them, it'll be a bit less eventually, maybe, I hope...
should know next week or so... was hoping for around 400-425rwhp, but as we all know - lots of little stuff can affect the numbers/devil is in the details for sure - it's an AT car, so that alone is a bit of a handicap for RWHP numbers... guess we'll see what all the goodies did to help offset that - as long as it melts tires, passes smog, and isn't a maintenance nightmare I"m going to consider it a success - getting lucky in it wouldn't be bad either!! ha!
of course, if my numbers are "just too low", that x-pipe of yours will be the 1st to go!!! hahaha! but like I said - it's easily melting tires already w/out ANY tuning or even the cold air intakes or airbox on!! yeehaa!
back to cams: IMO, application is the key factor when considering options w/cams, port sizes & valves - changes in geometry can yield some great rpm specific power #'s, but at a price in reliability/drivability more than any other NA stuff (spring tension/idle issues etc vs changes in displacement/stroke/FI) ... it just all leads back to that "all part of a balanced system of tradesoffs" thing, what's right for one app will be a disaster for another, so you need to establish the usage/goals before you can effectively determine the suitablilty of any deviations from OEM specs....
Old 07-10-2005, 06:17 PM   #22
slate blue
Quote:
Rob,
Marc
I'm currenrly getting two sets of euro cams reground by Piper in the U.K. I must admit Rob, I didn't find Elgin that helpful. Hard to get hold of and not that interested in the business. So I sent mine to the U.K. where they were keen to do the work. For the 4 valve engine they told me they would have plenty of grinds and sent me quite a few.
They quoted 400 pounds, which is about $750 USD. Also they said, without seeing them, they didn't think the cams were nitrided. They thought probably just black phosphate coated. They would investigate when the cams turned up. Does anybody know for sure if they are nitrided or not?
Still haven't got my 86.5 cam back as yet, but will post photos when I do.
Cheers Greg
slate blue is offline   Reply With Quote
Old 07-10-2005, 08:12 PM   #23
m21sniper
m21sniper's Avatar
Damn Lag, you get easily frustrated.
Take it easy on the ...you'll hurt yourself.
LOL.
Old 07-10-2005, 11:12 PM   #24
drnick
drnick's Avatar
i also had piper regrind my GTS cams closer to GT specs, have posted the duration/lift numbers before in other threads. finaly im getting very close to having the engine installed in the car and seeing it running at which time i will report more about the performance.
nick.
928 converted into mast for sailboat
85 IOR 50' - custom one off
02 e39 m5 450bhp
drnick is offline   Reply With Quote
Old 07-11-2005, 05:27 PM   #25
rob rossitto
User
hey greg, guess I got lucky w/elgins, or maybe it's a personal thing! ha! does help if you talk to the right guy for sure - camgrinder hangs out on the rennlist from time to time, was quite helpful... IIRC, he's the shop manager... but I suspect/ hope there's more than 1 competent shop on the planet
IMO, main thing is to get the indexing right, and use specs that are right for your app/build... I'd love to use some overlap, but smog #'s would've gone down the toilet... lots of trade offs/compromises for street cars...
IIRC, there's about .070" "play" in the OEM hydraulic lifters, but once you go beyond .020" over or so, it's time for solid lifters, different springs, different valve lengths, etc... whole different ball game, but awesome results at higher revs...
FWIW, specs I used are:
GT stock - .214 //.393 Intake
stock - .199.9//.353 exh
new - .218 //.404 intake
new- .208//.374 exh
all gains from reducing base circle, pretty modest changes...
dont' overlook coatings - IMO, the cams probably benefit more than most stuff w/a good nitriting/low friction coating process... lots of coating choices too - I used nitriting cause it was cheap/proven, although more exotic $tuff is out there (IIRC Brendon had a line on some interesting coatings)/might be worth trying for someone more adventurous/running more aggressive revs, pressures and lifts/etc....
Old 07-30-2005, 02:41 PM   #26
Camgrinder
User
camgrinder
Rob,
I left Elgins to start my own cam grinding business last November. Right after you bought your set of cams I believe.
Nitriding is highly recommended on 944 and 928 camshafts after being reground. After nitriding the phosphate coating is applied.
The .070" play you refer to is the lifters plunger travel. The typical lifter has about .050" preload. After regrinding the preload is reduced by .020".
Camgrinder is offline   Reply With Quote
Old 07-30-2005, 04:37 PM   #27
rob rossitto
User
Quote:
Originally Posted by Camgrinder
Rob,
aha! glad you're still around!!! a grinder speaks - lots of questiions for you here!!! you should get your sponsorship going - not too many cam pros around!!!
like: what's the pro word on using 85 cams in later MY heads???
regards!!
Old 07-30-2005, 06:54 PM   #28
slate blue
Hi Rob and Dr Camshaft, good info Rob, glad your having fun too. I agree, I don't see any down side in Nitriding. I would like to know the specific benefits of the nitriding or why it is needed, my cams are in England now and they are waiting on the headflow figures.
I will also post shortly, photos of my 85 models cams that have been modified, they cost me $440 AUD or about $325 USD to be done. Not cheap but I had sold my GT cams and I did want that slightly different timing on the intake due to the increased revs I have planned.
Cheers Greg
Old 07-31-2005, 06:12 PM   #29
Camgrinder
User
camgrinder
The factory 28 2v and 4v cams have a "tennifer" heat treatment . This heat treat is super hard, but is not very deep ( less than .005"). When the cam is reground the heat treat is removed. The tennifer heat treat process used cyanide gas, which is not allowed in the U.S.A.
Nitriding is highly recommended to restore the factory level of hardness.
"like: what's the pro word on using 85 cams in later MY heads??? "
I would have to look up the different specs on monday at the shop. The big problem with different
year cams is the factory lobe centers.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright © 1998 - 2007 Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
Emails & Contact Details
