Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 928 Forum
Sign in using an external account
Register Forgot Password?
This Rennlist Forum is sponsored by      ....dedicated to Your Porsche 928
Thread Tools Search this Thread
Old 08-21-2005, 12:49 AM   #1
Ed Scherer
Ed Scherer's Avatar
Default H4 HID Conversion Kit Installed; Writeup Now Available
A few weeks ago, I installed the 928 Specialists "H4 BI-XENON High/Low Beam Kit". I'm really happy with the results, so I figured I'd share the positive experience and pass along what I hope is some useful information.
I also told Dave Roberts that I'd write up the installation procedure I used, so that's available now as a 20-page Acrobat (PDF) document. Seems kind of long, I know, but it includes tons of photos and details of some modifications I made.
Ed Scherer is offline   Reply With Quote
Old 08-21-2005, 02:59 AM   #2
Ed Scherer
Ed Scherer's Avatar
Quote:
Originally Posted by borland
You might want to review your luminosity table. It appears that your HID high beam is less intense than the HID low beam. Looks like spot meter, did you use the garage door to locate the spot for each measurement? If so, then your probably not be capturing total lumens broadcasted. Starbrights may be defocused as compared with the HID. Brightness and luminosity are not the same measurement.
I suspect that since the "high beam" (such as it is) is done via reflector shift, the light output is just redirected over a larger area, and hence the lower illuminace at a particular spot. Like I said in the writeup, just taking the maximum illumination that I could find was a pretty crappy technique to use. I'd really like to follow up (when/if I have time, and perhaps if I sense enough interest from others) to set up a grid, take lots of measurements, and actually map out the beam pattern.
As to lumens and total light output, that's a spec that you can get from the bulb manufacturers. How those lumens actually become usable, as you probably know, is a matter of good reflector design, optics, etc.
Do you have any plans to replace the foglamp bulbs with Starbrights? I found they made a big difference with the high beam setting.
I also have the Starbrights in the headlights. If run the foglamp and low beams, it's a pretty broad lighting of the road, without glaring the driver in front's rear view mirror. Aiming is everything.
I'm just not sure about that yet. I'm still thinking about it. I'm not sure I want to lose the "quick flash" function of the H3 "assist" high beams, and I don't know if I'd want the "throw the light everywhere" HID bulbs for the H3 fog lights. I'll listen to other people's experiences with this before committing to any further changes. It's my understanding that the reflectors designed for transverse filament bulbs like the H3 don't fare so well (with respect to preserving a reasonbly good beam pattern) when you put in a more-or-less axial light source HID bulb.
Old 08-21-2005, 03:00 AM   #3
Ed Scherer
Ed Scherer's Avatar
BTW, I fixed a few problems in that original writeup. It's at revision 1.2 now.
Old 08-21-2005, 04:41 AM   #4
Bill Ball
Under the Lift
Bill Ball's Avatar
Superior guide, Ed. Very detailed and professional.
Bill
GP White '89 S4 - 242K carefree (well, almost) miles
SLC Motosport X-pipe - 928 Specialists RMB - '87 rear resonators - '83 LSD - Performance Shock, Inc. double-adjustable Konis with main/tender Eibachs - 2002 996 wheels - Momo Club 3 steering wheel - H4 HID headlights
Sharks in the Park XII, May 5, 2012 - Tilden Park, Berkeley, CA. - Pictures courtesy fo George Suennen.
If you live in North or Central CA, join our group at Norcal928.org
Bill Ball is offline   Reply With Quote
Old 08-21-2005, 04:20 PM   #5
Alan
Electron Wrangler
Alan's Avatar
Ed,
Very nice job! Can I use include your write up as one of the appendix sections in the Primer Document on projects for your 928 - its exactly the kind of thing I had in mind (I had a HID section placeholder in the outline) - I'd put it in exactly "as is" with yout copyright etc. Rich Andrade has created a similarly well done document on engine control... I'm hoping for more... you guys have created a great benchmark standard! and an outline format template for others.
Alan
1994 928 GTS Black/Black Manual "AZ Desert Sharks"
Official Rennlist Boffin
There are only 10 kinds of people in the world... those who understand binary and those who don't...
No rub strips!, H4's w/ remote adj, HID Fogs, Sat Nav, Bilsteins, 235/45R17 & 275/40R17 PS2's, Orange TPMS, V1+, 7 ch Audio, BT - much more...
Alan is offline   Reply With Quote
Old 08-21-2005, 04:56 PM   #6
Ed Scherer
Ed Scherer's Avatar
Quote:
Sure, if you'd like. I can't remember what your plans are for your document, but I'm hoping that this kind of stuff is just generally useful to people, whatever the distribution channel. I've gotten so much help from others; just trying to give some back.
Thanks! Well, I'd have to also say, though, that I'm trying to follow the lead of others who have done some great work... Tony Harkin, John Pirtle, etc., whose write-ups have made a huge difference in making it easier to dive into jobs that I might otherwise have avoided.
BTW, I've been a bit remiss in not sending you any review info on your doc. I actually took it with me on the flights to Spokane last week, but I wound up working on this HID write-up instead. My wife is off to California for a few days this week on business, though, so I'll have some quiet evenings when I hope to get to it. Unless, of course, the 928SP X-over exhaust shows up, in which case I'll be under my car instead.
Old 08-21-2005, 05:25 PM   #7
CWO4Mann
User
CWO4Mann's Avatar
Send a message via AIM to CWO4Mann Send a message via Yahoo to CWO4Mann
Wow! Very helpful. You must write technical manuals for a living. I've downloaded the pdf and printed it and it is now in my WSM set.
Thank you!
Dave
CWO4Mann is offline   Reply With Quote
Old 08-21-2005, 05:29 PM   #8
Bill Ball
Under the Lift
Bill Ball's Avatar
Quote:
Originally Posted by CWO4Mann
...You must write technical manuals for a living....Dave
That's exactly what I thought too.
Bill
Old 08-21-2005, 05:54 PM   #9
Ed Scherer
Ed Scherer's Avatar
Quote:
Bzzzztttt... sorry guys. I'm actually one of those software guys (mix of management and in-the-trenches development) who actually doesn't mind writing documents. But it's a pretty secondary (or tertiary, or lower) activity.
Good technical writers, though, are incredibly valuable. At a previous company I worked for, we had an extraordinarily good tech writer. Probably 10 times as productive as I could ever hope to be, yet higher quality than I could hope to be.
Regardless, it's a pretty satisfying thing to turn out a good document that turns out to be useful.
Old 08-21-2005, 10:01 PM   #10
tv
Super User
tv's Avatar
Great contribution ED! Thats what makes 928 ownership a great deal easier. Thanks
tv is offline   Reply With Quote
Old 12-22-2009, 04:53 PM   #11
JPTL
JPTL's Avatar
Ed,
Now 4 1/2 years after the 1st post of this thread, these kits have gotten much cheaper. I'm kicking around the idea of HID's. Are you still running HID's or have you gone back to standard bulbs so as to not offend oncoming motorists (I read Andrew's post in another thread)?
Have you revised your installation since 8/05?
Any attempts at HID in the H3 driving lights/high beam fixtures?
J.P.
'91 GT
Black/Classic Gray
'88 S4 5 Speed/LSD
Silver/Cancan over Black
'02 Kawasaki Concours (the Crown Vic of motorcycles)
The Official US Frenzy Site
There is a very fine line between "hobby" and "mental illness."
-Dave Barry
JPTL is offline   Reply With Quote
Old 12-22-2009, 05:06 PM   #12
Alan
Electron Wrangler
Alan's Avatar
I have HID in the H3 Fogs - works fine as long as you modify the reflectors a little to avoid stray upward lighting.
Alan
Old 12-22-2009, 05:10 PM   #13
Ed Scherer
Ed Scherer's Avatar
Quote:
Originally Posted by JPTL View Post
Ed,
Wow... hard to believe it has been that long!
Yup, I'm still running the HIDs. No changes since then, and they work great. I've got them pretty carefully aligned. I think I can remember only once over the entire four years that I've been flashed; that's probably no more often than with the old halogens.
The only thing I might do is try to seal the backs properly. I had to remove the original H4 seals on the back to make room for the HID bulbs, which extend way too far back to fit inside the original gray seals. I didn't think it'd be much of a problem, but I've noticed the inside surface of the glass has gotten a little cloudy — a bit of a film. I haven't thought much about how I'm going to do it, but I'd really like to do a cleaning and try to get them sealed up.
Old 12-22-2009, 07:02 PM   #14
JBrown
JBrown's Avatar
I would put the HIDs in the fogs to match the headlights. It would make it look so much better.
Everytime I put a set of HIDs in a customers car, within a week they come back to get the fogs done to match the headlights. Plus HIDs in the headlights and fogs give you assume light
83 911 cab/ 3.5 turbo 400rwhp- 88 944 turbo
www.soundfx-ny.com
JBrown is offline   Reply With Quote
Old 12-23-2009, 12:04 AM   #15
JPTL
JPTL's Avatar
I like the idea of matching HID in the headlights with the driving lights. Now it looks like that can be done for not too much $$. The Silverstars are decent, but far from the illumination that HID's are capable of. Currently I have 100w halogens in the running lights and use them as dusk headlights quite often. It would be nice to have these fitted with HID's. I can imagine the light that they alone must put out.
If I were to do HID headlights, I don't care much about the aux. high beams matching the HID headlights - in fact I'd like to keep the stalk-flash option. Plus, I get the sense that high beams become unnecessary with a properly set-up HID kit.
Re: cleaning the reflectors and inside glass of these fixtures, I can imagine that such brilliant light must accentuate any cloudiness/streaks. I've always thought that those no-wipe chandelier cleaning products might work well for the non-reachable parts of the fixutures. Supposedly no-wipe & don't leave a film.
JBrown, hopefully your 928th post isn't wasted on a forum other than this one
J.P.
'91 GT
Black/Classic Gray
'88 S4 5 Speed/LSD
-Dave Barry
Tags
az, brightness, cars, conversion, fit, forum, h4, headlights, hid, hids, kind, kit, lumens, measurement, phoenix, shawneeks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright © 1998 - 2007 Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
Emails & Contact Details
