928 Forum 1978-1995
Sponsored by: 928 Specialists
The Twin Screw Thread
Old 12-09-2005, 04:29 PM
Jim_H
Jim_H's Avatar
Default The Twin Screw Thread
With Andy phasing out of the TS world and many of us having his systems there are a lot of questions and ideas that I think arent going anywhere. Maybe this can be a thread where we can do some Q & A and maybe improve on what we have. Maybe even swap some parts.
For instance, somehow the fact that the pre S4 radiator hose (ds) remedies the cut hose problem didn't get passed along to all.
Critiquing the system is fair game also, especially if there is a solution by the critquer
Old 12-09-2005, 05:26 PM
Jim_H
Jim_H's Avatar
928 SP SC link
https://rennlist.com/forums/928-forum/230957-sneak-peek-supercharged-by-928-specialists.html
Customized Supermodel set up.
https://rennlist.com/forums/928-forum/242306-sc-install-with-links-to-pics.html
Old 12-09-2005, 05:31 PM
Tony
Tony's Avatar
Also, if you have the snout support with the 3 aluminum cyclindrical spacers on the back...CHECK them. One of the spacers on Darriens "kit" was a different length. If it was supposed to be that way, i havent seen anything to show me that?
It skewd the whole alignment of the tensioner/ilder pulley and messed it up. Scuffed up a SC belt as well when the car was first started and the belt found its comfortable running position.....half of it folded up on to the AC pulley!
By adding a couple of thin washers to the spacer i got Darriens belt running smack dab in the middle of the idler pulley.
Ive got a few things relating to the I/C system that cleans it up a bit. The newer manifolds have the I/C inlet pipe on the top. The older ones were in the front and allowed for a more stealthy run of hose to the heat exchanger.
I fab'd up a 180' turn for Darriens so the hose can now run under the snout and down along the lower rad hose where it eventually meets the heat exchanger inthe front bumper.
this was the copper fitting i made
Ill get a pic of it at some point. Its not really needed, but we didnt care for a big 3/4" hose coming off the top of the manifold towards the passenger fender area.
Also, something im looking into eventually is some more boost. With a swap to a smaller pulley i think you will run up against some significant belt slip as we dont have the nice belt wrap like DR has on his setup
Another way to increase the boost besides going to a smaller upper pulley is to make the lower pulley bigger
I havent tried it yet or done the math on the pulley ratio/boost etc. but believe it or not, the MURPH lower pulley may be useable on the TS set ups. Even though Murph uses 8 rib and the TS 6rib, the plane that they run in is the next position fwd of the AC pulley. This would give you a larger LOWER pulley instead of a smaller upper......as not to get to wild you would probably have to go to a slightly bigger upper pulley also(hood clearnce???..dunno)! Just a thought for you Jim....since 460 HP isnt enough
top...stock
middle...TS
bottom ...MURPH
Old 12-09-2005, 07:24 PM
Daryl
Daryl's Avatar
Jim,
I think this is a great idea! As well there are people out there that are about to install their SC who need Tech help.
My car was running open loop, not using a CO sensor. If anyone needs help in that area let me know.
I like the look of Bills throttle cable setup. Any chance of getting more info on that?
Heres a picture of my fresh air intake. Easy to do.
Old 12-09-2005, 07:39 PM
Tony
Tony's Avatar
BINGO.
Details on that Daryl. We are looking for some solution on Darriens 86.5..what did you have to move to do that.
Coil....jumpstart terminal?
Pics please...inside the fender as well. I like it.
Good idea ya posted here Jim
We are using Bills set up on Darriens car also. Gives a nice clean approach for the cable to the throttle linkage on the TB.
Ill grab pics next time i go up there.
Old 12-09-2005, 08:30 PM
MrLexse
MrLexse's Avatar
Could this be done on the Supermodel forum, or is it defunct?
Old 12-09-2005, 08:45 PM
Shane
Sharkaholic
Shane's Avatar
Sad to say but.... I am almost relieved that my car went up in smoke. Now I am free of the whole cobbled together mess and can start fresh with a more user friendly system that has some REAL customer support!!
I miss my car, I miss running a 928 with boost but not much else....
Old 12-09-2005, 08:48 PM
Jim_H
Jim_H's Avatar
A bigger lower pulley... I like it. What boost do you run consistently Tony and do you have to tighten your belt a lot to keep your boost up.
Old 12-09-2005, 08:50 PM
Tony
Tony's Avatar
IMHO...From what i can gather people arent being given the time of day on that forum from the person that should be giving it.
So, why give the forum the traffic and the owner the return favor.
There is a great wealth of knowledge and diversity on THIS forum alone that can be of benefit to the folks out there who run the twinscrew. The people who provide it dont have access to the "supermodel" forum and most likely arent TS owners, so if they want to chime in on this thread they are more than welcome to and dont have to be "approved" to do so..
I imagine over time the thread here will fall off the pages or perhaps turn into a TS vs CS vs TURBO debate but in the mean time it seems like a pretty good idea?
Old 12-09-2005, 08:51 PM
Jim_H
Jim_H's Avatar
No doubt there are better ways to end the Supermodel system than the way Andy has. I think he is just burned out. Are you selling the TS?
Old 12-09-2005, 08:55 PM
Shane
Sharkaholic
Shane's Avatar
I am. Or already have as soon as I can get it off the car and shipped to Warren. He has a partial from Andy, so maybe with what is usable from mine and what he has already got, he can put together a useable system.
Old 12-09-2005, 08:56 PM
Tony
Tony's Avatar
i seem to run appx 7-8lbs on most of the logs i have looked over. I havent tightened my belt in a while and im sure it could use it, but i need a shorter belt really. I have placed marks on the belt and the SC pulley and it does slip now and then.
Old 12-09-2005, 09:01 PM
Shane
Sharkaholic
Shane's Avatar
At sharktoberfest Bill and Derek, mentioned that the inlet and relief on the BEGI was backwards causing full rich conditions which I had any time I ran 30# injectors. Does anyone have a diagram on how it is supposed to be? Might help future installers from going down the same road.
Old 12-09-2005, 09:07 PM
BC
BC's Avatar
Tony are you going to try for 10 or 11? I'd really like to see the power curve on that. It would be great to compare that to whomever else has gone that high. Do you have enough fuel for that?
Old 12-09-2005, 09:47 PM
EB338
EB338's Avatar
Has anyone taken over from the Supermodel kits? Are the 928 Specialists kits the continuation of what was being done? They sure look similar. Do they have the same intercooler manifold setup? How close are they or are they the same thing, or am I totally out in left field here?
Quick Reply: The Twin Screw Thread
