928 Forum 1978-1995
Sponsored by: 928 Specialists
Aluminum Foil for Exhaust Leak
Old 12-28-2005, 12:15 PM
James-man
James-man's Avatar
Default Aluminum Foil for Exhaust Leak
At a recent DE event, I had planned to take the time to recheck the Motorsport X pipe clamps to see if they were tight enough. Too late for one side! I had already blown the fiberwrap out of one. Actually I had suspected that something was amiss as I starting hearing the leak. Shoulda checked earlier!
I brought extra brakes, oil, tools, but no extra fiberwrap. So off to the concession stand I go. They gave me a 2 foot long sheet of aluminum foil and I folded it a couple of dozen times to generate some thickness. Installed & reclamped. It lasted the remainder of the weekend and the long drive home. Still in there and no exhaust leak.
May be Mickey Mousing it, but it eliminated an exhaust leak and allowed me to fully enjoy my DE weekend.
Anyone ever consider including a roll of aluminum foil in your just-in-case boxes? Yeah, me neither.
Old 12-28-2005, 01:15 PM
k1woods
k1woods's Avatar
fiberwrap? I was wondering what those were for!! duh!- I thought they were packing/shipping materials...
Can you buy extra fiberwrap?
Old 12-28-2005, 02:34 PM
James-man
James-man's Avatar
I have no idea where you get it. You might check with your X supplier for sources.
Old 12-28-2005, 02:35 PM
James-man
James-man's Avatar
BTW - I am keeping the foil in until I happen to stumble upon a local source for the stuff.
Old 12-28-2005, 04:54 PM
k1woods
k1woods's Avatar
I'm a happy Motorsport X-pipe owner. I'll try the foil as well. Worst case I imagine would be to buy another set of clamps. Thanks.
84 928 S2
Old 12-28-2005, 05:11 PM
James-man
James-man's Avatar
Dave Lomas mailed my muffler wrap to me separately. Maybe he could do the same for you?
If you try the foil, you will probably be surpirsed at how much foil it requires. The foil I "borrowed" was extra wide commercial sized. I folded it accordion style thinking it would be the most durable and pliable that way. Maybe I was right?
I too am a happy owner. My car looks just like yours 'cept yours is a euro, eh? I would be very curious to hear how different our visibly similar cars sound with X pipes installed.
Anyhow, I am thinking about adding X + Reynolds Aluminim Foil to my sig line. Not really.
Old 12-28-2005, 05:22 PM
the flyin' scotsman
the flyin' scotsman's Avatar
What fibre wrap?..............never did receive any.
Is it the correct sealing solution anyway given the issue?
Old 12-28-2005, 05:42 PM
James-man
James-man's Avatar
X pipe inside diameter is just about the same as the resonator pipes outside diameter. The resonators' pipes go in an inch or two, as I recall.
How would you go about sealing the two? What you consider to be correct? I am thinking that a shim/sleeve with one side cut full length would do the trick, but you could still have a teeny tiny exhaust leak.
The woven wrap material seems like the easiest solution while leaving all X-back exhaust system options wide open. It looks kinda like a tie-down strap. If you install it, cinch the clamp down tight and recinch it later.
For anyone that is interested, I plan to dyno in the spring. I think the alumininum foil may be good for an extra 2 HP but since I only have it on one side, make that +1...
Old 12-29-2005, 08:49 PM
k1woods
k1woods's Avatar
Hey James - Are you sure you need the Fiberwrap? I have no leaks without them?
Also, did a web search on various types of Exhaust Band Clamps and none of them show any kind of additional seal?
84 928 S2
Old 12-29-2005, 09:51 PM
the flyin' scotsman
K1................I never received the fibrewrap with my Motorsport X; I believe Canadian customs has it and my exhaust leaks at the X/ resonator joint. I'm going to try an exhaust foil wrap to make up the diamenter difference and reclamp.
Old 12-29-2005, 10:28 PM
Garth S
Garth S's Avatar
You might consider a finger-full of the 'Red' polymer sealant frequently used in exhaust systems, sold at all auto supply stores. There are various brands, and the stuff is non hardening.
Permatex is one ... quote:
"Permatex® High Temp Form-A-Gasket® 1372 Sealant
Slow setting, non-hardening, high temperature sealant. Especially recommended for heavy-duty applications. Temperatures range from -65˚F to 600˚F (-54˚C to 315˚C) intermittent. Resists common shop fluids. Suggested applications: Coating and sealing exhaust gaskets, flanges and connections, and other heavy duty applications."
Old 12-29-2005, 11:18 PM
the flyin' scotsman
thx Garth..........I'll check out the 'local' NAPA tomorrow.
Old 12-30-2005, 10:34 AM
James-man
James-man's Avatar
84 928 S2
It could be that I should have used a smaller size of band clamp. I tightened on the smaller diameter pipe as far as the clamp bolt threads would go. then the question would follow, would the smaller band clamp make it around the larger diameter pipe? Dunno.
Aggressive braking probably worked the exhaust loose. I probably would have been fine if I were just doing a little around the town driving or highway cruising.
Old 12-30-2005, 02:47 PM
Herr-Kuhn
Herr-Kuhn's Avatar
As Mickey Mouse as it sounds, aluminum foil can be wrapped around a lot of components to make an effective heat reflector. It is cheap and it works. My hood liner is two layers of low cost carpet padding covered in three layers of aluminum foil.
Old 12-31-2005, 02:26 AM
Randy V
Randy V's Avatar
Great. Now even rednecks are driving 928s.
Quick Reply: Aluminum Foil for Exhaust Leak
